ACE sticky routing where port 80 and port 443 stick on the same server
rhaggart
We have a server load balancing configuration where we want incoming site visitors to stick to the same physical server regardless of whether they entered on port 80 or port 443 (SSL terminated by ACE).  For example, if an incoming site visitors arrives on Port 80 and sticks to Server 1, if that user then clicks on a secure port 443 link, we want them to stay on Server 1 on Port 443.  In our current configuration, we can get them to stick to one server on Port 80 and Port 443 independently, but we have not been able to find a way to ensure visitors who are stuck on Server 1 on Port 80, will also be stuck Server 1 if they switch to Port 443.  Ideally, the sticky sessions would be based on our application session cookie, but we could also use source IP or cookie insert if it was required to meet or requirements.
Can the scenario described above be done on the ACE?
Fabio Jorge
Hello Rick, let me understand more deeply. Do you want a single connection from client to Ace port 80 and 443. If the user calls http port Ace redirect to https and send to same vserver running the aplication. If the client calls https go to the same server  above.
is it ok? If yes tell me and i send you the script to that.
Cheers
Fabio Jorge Amorim
Hello Fabio.  I will try and clarify. Our application has secure (port 443) and non secure (port 80) pages.  So waht we want is the client to be able to connect to be able to go back and forth between 443 and 80 connections and stick to the same server. The problem we have currently is that the sticky sessions on port 443 and port 80 are independent of each other so it is possible that the client is stuck to Server 1 for 443 and Server 2 for 80 which causes their application session ID to be reset when they switch between 443 and 80. Does that make sense?
Thanks for your help.
Rick
Hello Rick, Now it´s clearly for me. I understood your problem. I would like to encorage you to do some change at your environment.
I have similar design but i work with application sharer between both servers.
I recomend you take a look at design below, sorry about English grammar mistakes. I´ve been studying hard to get English as second language.
===========> Customized probe especific to application  <===========
---> I like to get information direct at application, in this case is deployed an espeficic url where I get the status <---
probe http HEALTH_CHECK_SITE_FARM01
  port 8080
  interval 30
  passdetect interval 60
  passdetect count 1
  request method get url /validate/index.html
  expect status 200 200
  expect regex "validatet:OK"
===========> Rserver hosts  <===========
rserver host SRV01
  ip address 10.10.10.10
  inservice
rserver host SRV02
  ip address 10.10.10.11
  inservice
===========> Creadte a http parameter  <===========
parameter-map type http http_parameter_map
  case-insensitive
  persistence-rebalance
  set header-maxparse-length 8192
===========> Create a farm with both servers <==========
serverfarm host FARM01
  probe HEALTH_CHECK_SITE_FARM01
  rserver SRV01 8080
    inservice
  rserver SRV02 8080
    inservice
==========> Create a sticky to both servers <===========
---> This timeout is to browser expire, for example is the user idle during 2 minutes <---
sticky http-cookie FARM01 COOKIE_FARM01
  cookie insert browser-expire
  timeout 120
  replicate sticky
  serverfarm FARM01
==========> SSL terminator to serverfarm <===========
ssl-proxy service SSL-FARM01
  key fabiojorgeamorim.com.br.key
  cert fabiojorgeamorim.com.br.cer
  chaingroup RSA-CA
==========> Policy to VIP <===========
---> I like to work with segregate policy, it´s good in caso of management etc <---
class-map match-all VIP-FARM01-HTTP
  1 match virtual-address 10.10.20.10 tcp eq 80
class-map match-all VIP-FARM01-HTTPS
  1 match virtual-address 10.10.20.10 tcp eq 443
==========> Policy to sticky/serverfarm com x-forward header http <===========
policy-map type loadbalance first-match policy_FARM01-HTTP
  class class-default
    sticky-serverfarm COOKIE_FARM01
    insert-http SSL header-value "OFF"
    insert-http x-forward header-value "%is"
==========> Policy to sticky/serverfarm com x-forward header https <===========
policy-map type loadbalance first-match policy_FARM01-HTTPS
  class class-default
    insert-http SSL header-value "ON"
==========> Here you can apply policy configuration and enable the application access <===========
policy-map multi-match PM_CTX01
  class VIP-FARM01-HTTP
    loadbalance vip inservice
    loadbalance policy policy_FARM01-HTTP
    loadbalance vip icmp-reply
    appl-parameter http advanced-options http_parameter_map
  class VIP-FARM01-HTTPS
    loadbalance policy policy_FARM01-HTTPS
    ssl-proxy server SSL-FARM01
This scenario you will be able to permite both connection "http and https" to both servers and a single STICKY.
If you will go ahead let me know, it´s a pleasure to share some technical experiencies.
ACE example and topology
http://www.4shared.com/folder/pGkMpHxk/ACE_Example.html
I hope help you, let me know you have further question.
Fabio Jorge Amorim
Thanks very for the detailed example Fabio.  We will test this approach and let you know the results.
Rick
