ACE TCL Script to retrieve Cookie
tthulin
I am in need to to do a post instead of a Get with a probe. So I have configured a TCL script to perform this. The issue I have is that I also need to parse the Cookie instead of the http1. response. Any ideas? Or does anyone have a variable indetifiers for TCL scripting that Cisco uses?
Thank you,
Tim
sachinga.hcl
Level 4
Level 4
HI Thulin,
Health probe scripts have access to many configured items through a predefined TCL array. The most common use of this array is to find the current real server IP addresses of the suspect during any particular launch of the script.
Whenever the ACE executes a script probe, a special array called scriptprobe_env is passed to the script. This array holds important parameters that may be used by the script.
Member name Content
realIP
Suspect IP address
realPort
Suspect IP port
intervalTimeout
Configured probe interval in seconds
openTimeout
Configured socket open timeout for this probe (tbd)
recvTimeout
Configured socket receive timeout for this probe
failedTimeout
Configure failed timeout
retries
Configured retry count
healthStatus
Current suspect health status
contextID
The ID for the context running this script
failedRetries
Consecutive successful retries on a failed server before marking it as passed
isRouted
Boolean to determine if this IP address is a routed address
pid
Process identifier of the TCL process
runID
Pointer to the event structure (em_event_t)
Kindly refer to the following url to get more info regarding your tcl variables:
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/v3.00_A1/configuration/slb/guide/script.html#wp1082112
http://www.cisco.com/univercd/cc/td/doc/solution/dc_ap11i.pdf
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/mod_icn/ace/ace_301/slbgd/script.pdf
Sachin Garg
