ACE-TCP RST, ACE initiated RST
s.srivas
Hello members,
What is the command to identify if ACE is initiating TCP RST?
Is there a way to overcome or change timers/window/ect, if ACE do initiate TCP RST?
Thanks in advance members.
6 Replies 6
Roble Mumin
Level 3
Level 3
There are some default timeouts e.g. idle tcp sessions 60 minutes. You can change those if desired.
Create a TCP Parameter Map change what you want and apply it globally. If you want to check what happens with a flow you imho need to capture packets in the corresponding context.
Maybe someone else has even better advice.
Roble
Gilles Dufour
you can use the following command to see the TCP stats.
show np 1 me-stats "-s tcp"
There are RESET counters.
However, you don't know why the reset was generated and modifying all kind of parameters without knowing the true cause of the RESET is a little bit dangerous.
You should capture a sniffer trace and try to understand the reason of the reset.
Gilles.
Thanks Giles.
Very useful command
I'll look at the capture file that was done couple of days ago.
I'm attaching the show output, just collected. Any clues will be appriciated.
switch/001_snippedcus#
switch/001_snippedcus# show np 1 me-stats "-s tcp"
TCP Statistics: (Current)
TCP RX messages received: 0x50bc5841
TCP RX unknown messages: 0
TCP RX racing messages (fin): 6815
TCP RX racing messages (forward): 199102
TCP RX racing messages (conn create): 170
TCP TX messages received: 0x41fa25a8
TCP TX Hi Priority messages received: 14002856
TCP TX unknown messages: 0
TCP TX racing messages (connect): 7
TCP TX racing messages (data): 1884954
TCP TX racing messages (proxy): 8066793
Reproxy message received: 0x073533fd
Data messages received: 0x2a741cdc
TCP connect message received: 0x02639a8a
Ack trigger message received: 3036
Unproxy req. message received: 0x07d7f2ce
Unproxy rsp. message received: 0x07cacdc4
TCP accepted msgs sent: 0x01343370
TCP connected msgs sent: 0x0263408b
Conn_ctrl msgs sent: 5029091
Buffer alloc failed: 0
Invalid msg ring id: 1218
Start retrans timer: 0x1f175a0c
Start ackdelay timer: 0x171d7346
Start persist timer: 300659
Start timewait timer: 0
Delete act timer: 0x16ee4b8f
Delete rtp timer: 0x1e3ee16d
Connections unproxying: 0x07cacfa5
Connections unproxying canceled by TCP: 833690
Connections unproxying canceled by app: 156752
Connections unproxying immediate reproxy 0x0315f058
Connections unproxying flush retransq: 0x07c2788a
Connections unproxying flush inputq: 0x02167109
Connections unproxied: 0x04829af2
Connections reproxied: 0x039a94a0
Drop reproxy msg queue full: 2916
Drop control msg: 7972
Drops due to FastTX queue full: 0
Drops due to Fastpath queue full: 0
Drops due to HTTP queue full: 134145
Drops due to SSL queue full: 0
Drops due to AI queue full: 0
ACK past SEQ: 36504
Unproxy rsp post failed: 207
Drops due to invalid proxy id: 0
(Context ALL Statistics)
Handshakes completed: 0x0395731f
Handshakes failed: 150512
Packets received to app: 0x2ad1fc92
Packets sent to network: 0x57f27343
Segs outside window: 524277
Dup ACKs received: 0
Dup ACK limit met: 0
Malformed TCP options: 0
Reassemble segs: 806787
Nagled data segs: 0
Retransmitted data segs: 0x065e16c4
Round-trip timeouts: 10595624
Round-trip timeout limit met: 385691
Persist timeouts: 70351
..... see attachment, as this exceeds char limits
Hi Gilles,
I have a screenshot of a capture and thinking of sharing this in private, if your time permits. Please let me know.
SS
I had a look to your data but can't tell the reason for the resets.
Another command you could collec is
show np 1 me-stat "-s icm"
It will tell us if there was connection time out.
If you need to send me private data, you can do it to gdufour@cisco.com.
I'll answer only if time allows me to.
Gilles.
Gilles,
Thank you verymuch for this offer. I'll send the details direct to you.
