ACE two simple questions
danilodicesare
Level 3
Level 3
Hi all,
i've got two simple questions:
     1     resource class allocation, minimum is guaranted, maximun if unlimited means that i can exceed minumium, am i right (ex sticky)?
     2     sticky database, release before 3.2.5 (appliance) when  command show sticky database was performed i was able to decode (for ip sticky)
            ip address from notation withaout '.' to notation dotted, i could see 9 numeric digit, now i can see 18 numeric digit....how can i decote it from
            XXXXXXXXXXXXXXXXXX to somethig like XXX.XXX.XXX.XXX?
tnx a lot for any response.
Dan
Narayan Subramanian
Dan
Answer to the first question is true but it does not apply to Sticky. Sticky resources cannot be oversubscribed and the minimum allocation equals the maximum allocation
2) i am not exactly sure what you are referring to here but if it is the vlaue of the sticky-entry then it is actually the hashed value ok the sticky in the database
Narayan
Hi Narayan,
i mean:
OLD STYLE prior 3.2.5
pippo-ace-01/pippo# show sticky database
sticky group : pippo_FARM_STICKY
type         : IP
timeout      : 10            timeout-activeconns : FALSE
  sticky-entry          rserver-instance                 time-to-expire flags
  169387028             pippo_1:0                          0              -
10.24.164.20=169387028
NEW STYLE 3.2.5
ACE-pippo/pippo# show sticky database
type         : IP
timeout      : 60            timeout-activeconns : FALSE
  9981152781572271311   pippo-2:0                 2712
   9981152781572271311=????????      -
tnx
danilo
Dan
The command was resolved to display the addresses in dotted decimal format from A3(2.6) . I am not sure whether this was done in A3(2.5)
Have a look at the release notes and look for CSCte57497
http://www.cisco.com/en/US/partner/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA3_x/release/note/RACEA3X.html#wp508369
Narayan
tnx but i've got 3.2.5...........
so i'd like to translate from 18 digit to dotted decimal...
