ACE VIP when using sticky and all servers offline does refuse TCP connect
arnstran
If the VIP uses a serverfarm and all servers are down, the TCP connections to the VIP are refused. Good.
If I use the same serverfarm in a sticky-serverfarm then the TCP connections to the VIP are not refused.
Are there anything that can be done to make it work the same for sticky as for non-sticky.
We run A2(1.3) software.
Relevant config:
parameter-map type http http_parameter_map
persistence-rebalance
rserver host alp-kunde-004
ip address 10.46.178.58
inservice
rserver host alp-kunde-005
ip address 10.46.178.59
inservice
serverfarm host HTTP-back.kunde.com12100
probe Probe-HTTP12100
rserver alp-kunde-004 12100
inservice
rserver alp-kunde-005 12100
inservice
sticky http-cookie ACE-COOKIE STICKY-HTTP-back.kunde.com12100
cookie insert browser-expire
replicate sticky
serverfarm HTTP-back.kunde.com12100
class-map match-all HTTP-Inbound-back.kunde.com_TCP12100
2 match virtual-address x.x.x.x tcp eq 12100
policy-map type loadbalance first-match Forward-to-RealServer-back12100
class class-default
sticky-serverfarm STICKY-HTTP-back.kunde.com12100
policy-map multi-match TRAFFIC-TO-VIP
class HTTP-Inbound-back.kunde.com_TCP12100
loadbalance vip inservice
loadbalance policy Forward-to-RealServer-back12100
loadbalance vip icmp-reply active
nat dynamic 58 vlan 1870
appl-parameter http advanced-options http_parameter_map
Gilles Dufour
Your sticky setup makes the connection L7.
So we spoof the connection and will always terminate it.
Which means we will always complete the TCP 3-way handshake, wait for the data from the client and then try to locate a server.
Only then we see there is no server available and we close the connection.
If you change your sticky rule to sticky source ip, you then keep the rule as L4 instead of L7 and we can detect the server down with the first SYN.
Gilles.
