ACE Web Application firewal & Architecture
Please I need your help. I'm configuring a cisco ACE XML solution, but I don't understand what are differences between the appliance's license.
1. Can I delploy ACE Web filtering in one appliance?.
2. What type of license I need if I want to protect of Cross-scripting, HTTP parameter manipulation, Protocol compliance, etc attacks?
3. Can I deploy a solution only with an Web Gateway? (without an ACE Manager).
Thank you for your help.
Best regards,
DT.
jim_berlow
Level 6
Level 6
I'll tell you what I know (I'm still learning myself).
1. Yes this can be done. Setup the AXG to run in stand-alone mode (basically the one unit serves as both manager and gateway).
2. Don't know the answer to this one yet so I can't help with this question.
3. See #1. A single unit can run as both a manager and a gateway, but the manager is required. FWIW...most of the cost of the manager is the licensing so you won't save that much money by loading it all on one box.
I hope that helps,
Jim
huangedmc
Level 6
Level 6
You don't need the full blown AXG license, but just the Web App Firewall license.
