ACE - Weight
t.waechter
Community Member
i have a Serverfarm with 2 Real Servers configured with RoundRobin Load-Balancing.
Now i want the traffic distributed to the same rserver all the time, except the probe failed.
Can i just turn up the weight to 100 for one rserver to stick the traffic to it?
ciscocsoc
Level 9
Level 9
No.
You either need to define a backup rserver in your serverfarm:
serverfarm host FARM-sql1-Mirror
description SQL Serverfarm Mirror
probe PROBE-sql
rserver sql1-Mirror
backup-rserver sql1-Node2
inservice
rserver sql1-Node2
inservice standby
or define two serverfarms - one server in each and then use one as a backup serverfarm:
serverfarm host FARM-web2-Master
probe PROBE-web2
rserver cc250-master
inservice
serverfarm host FARM-web2-Slave
probe PROBE-web2
rserver cc250-slave
inservice
policy-map type loadbalance first-match LB-POLICY
class class-default
serverfarm FARM-web2-Master backup FARM-web2-Slave
Which you choose is down to personal preference and if you need to be able to use more than one server in future.
Cathy
ciscocsoc
Level 9
Level 9
No.
probe PROBE-sql
rserver sql1-Mirror
inservice
rserver sql1-Node2
inservice standby
probe PROBE-web2
inservice
probe PROBE-web2
rserver cc250-slave
inservice
class class-default
Cathy
