ACE with SSL Termination issue
silk
Level 2
Level 2
I've configured a bridge mode context to do ssl termination for one specific VIP, port 443 outside to port 80 inside.
The problem I'm facing is something that resembles a MTU issue:
if I browse for simple html pages everything works fine, but if I start a file download (via HTTPS) the connection times out.
If I remove the ssl-proxy statement from the service policy, everything is all right and the file trasfer (via HTTP) works flawlessly.
Any ideas?
Thanks in advance.
S.
amacuz
Level 4
Level 4
Hi Silk,
have you tried to spot at which stage the connection times out?
Try to collect captures from the client and server and see what may be the problem.
Does the SSL phase complete?
Which version of the ACE are you running?
Alessandro
Alessandro,
thanks for the reply.
I'm already doing some packet captures to check the connection  phases (on the ACE and on the client - I've got no access to the servers) but
everything *looks* regular... for some reason the return traffic from the balancer seems to just hang somewhere, but not happening if the ACE is not ssl-proxing the flows.
I can see the replies coming from the server in cleartext but...
On the client browser side, the ssl handshake works normally, the cert is received from the LB and there is no warning in the browser.
ACE Module version is:
Software
  loader:    Version 12.2[123]
  system:    Version A2(1.6a) [build 3.0(0)A2(1.6a) adbuild_08:46:04-2009/10/16_/auto/adbu-rel4/rel_a2_1_6_throttle/REL_3_0_0_A2_1_6
S.
This is the relevant config of the LB:
access-list ROUTING line 8 extended permit ip any any
probe tcp TCP_80
  interval 10
  passdetect interval 10
rserver host 1.1.1.24
  ip address 1.1.1.24
  inservice
rserver host 1.1.1.25
  ip address 1.1.1.25
  inservice
ssl-proxy service PROXY_webservice
  key ACE_Key.pem
  cert webservice.cer
serverfarm host 10.1.1.23_TCP_443
  probe TCP_80
  rserver 1.1.1.24 80
    inservice
  rserver 1.1.1.25 80
    inservice
sticky ip-netmask 255.255.255.255 address source Sticky_10.1.1.23_TCP_443
  timeout 10
  replicate sticky
  serverfarm 10.1.1.23_TCP_443
class-map type management match-any ICMP-RESPONSE
  2 match protocol icmp any
class-map match-all Class_10.1.1.23_TCP_443
  2 match virtual-address 10.1.1.23 tcp eq https
policy-map type loadbalance generic first-match Policy_10.1.1.23_TCP_443
  class class-default
    sticky-serverfarm Sticky_10.1.1.23_TCP_443
policy-map multi-match LB-Policy
  class Class_10.1.1.23_TCP_443
    loadbalance vip inservice
    loadbalance policy Policy_10.1.1.23_TCP_443
    loadbalance vip icmp-reply
    ssl-proxy server PROXY_webservice
interface vlan 2
  description webservice_to_SERVER
  bridge-group 1
  no normalization
  mac-sticky enable
  no icmp-guard
  access-group input ROUTING
  service-policy input ICMP-RESPONSE
  no shutdown
interface vlan 22
  description webservice_to_FW
  bridge-group 1
  no normalization
  mac-sticky enable
  no icmp-guard
  service-policy input LB-Policy
  no shutdown
interface bvi 1
  ip address 1.1.1.21 255.255.255.240
  alias 1.1.1.20 255.255.255.240
  peer ip address 1.1.1.22 255.255.255.240
  description webservice_BRIDGE
  no shutdown
Key and Cert are installed and verified correctly.
Packet sniffing shows cypher exchange successful and the certificate is ok on the browser side.
Still the transfer hangs.
Removing the "ssl-proxy server PROXY_webservice" from the service policy and going cleartext on port tcp/443
shows that everything else is working correctly and there are no hangs.
Is there something I can check to clear if the LB is acting weird?
This LB is one of a hot standby couple, switching to the secondary one did not solve the issue.
Thanks.
Tip for the record.
issue has been solved by myself simply:
  class class-default
Bye!
