ACE20 Connection Counter
edwinchungath
Community Member
Dears,
Please find the below ACE Server farm Statistics details. The strange thing is the Current Count is higher that total count.
Any Idea......
show serverfarm ABCD_SFarm detail
serverfarm     : ABCD_SFarm, type: HOST
total rservers : 2
description    : -
predictor      : ROUNDROBIN
failaction     : -
total conn-dropcount : 0
                                                ----------connections-----------
       real                  weight state        current    total
   rserver: ABCD_01
       172.16.64.21:8080     8      OPERATIONAL  13486      289
         total conn-failures   : 0
   rserver: ABCD_02
       172.16.64.24:8080     8      OPERATIONAL  3960       289
Rgds,
Edwin
kitanaka
Level 5
Level 5
Hi, Edwin
What version are you running with your ACE20 ?
There was a bug with the currnt conn counter that was fixed in A2(2.4) and A2(3.2).
CSCtc94844 : ACE:  show serverfarm current connection counter incorrect
Integrated-releases : 3.0(0)A2(2.4)  3.0(0)A2(2.3.1)
Using A2(2.4) and A2(3.2) or newer code, this bug should not be happened.
Kimihito.
Thank you Kimihito for your valuable information
Presently ACE20 is running with 3.0(0)A1(6.3) Software image. So I believe this ver. is affected.
So as you said we need to upgrade A2(3.2)., I searched for the prerequisite for this ver. but could not find anything.
Is there any prerequisite for this ver.?
Thanks in advance.
Edwin
As documented in the A2(3.x) Release Notes here:
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/vA2_3_x/Release/Note/RACEA2_3_X.html#wp546483
To upgrade your ACE software to version A2(1.0) or higher, your ACE must be running software version 3.0(0)A1(5a) or higher.
Also, you should not upgrade to A2(3.2), but it's replacement, A2(3.2a).
