aces and soap
aamercado
Level 4
Level 4
HI
Problem - During a web session, with SOAP coding within HTML, there is a code reference header url //abc.com. Clients cannot access this particular ACE serverfarm website when we have this code, but when we modify it to the specific web server (ie //abc-web#1.rms.com) it works
I did not think ACE looks within the HTML code, just the url so cannot explain this? how do I troubleshoot?
ohynderi
ACE won't look at the http payload exepted if you have an ACE 4710 configured with application acceleration.
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA4_2_0/configuration/app_acc_and_opt/guide/app_acc_and_opt.html
It may look at the http header if you have some L7 policy-map / class-map configured. Can you show the relevant part of your config as well as the full http request (GET/POST) that you are doing?
Olivier
