Active conns view wrong in web manager.
danielspallamagalhaes
Community Member
I have a problem in the ACE 4710. In view of the connections of a web environment. When I view connections on Config> Operations> Real Servers, Conns column values ​​appear very high connections (Example. 1606317769078).
Already in Config> Operations> Virtual Server the number of connections appear normal.
Does anyone know how to solve this problem?
Version 4710 ACE Device manger A4 (2.1a)
chrhiggi
Level 8
Level 8
Hello Daniel-
Sounds like you found a bug.  Get a TAC case opened, they will need to see a showtech from the context you are working with and they will want a screenshot of what you are looking at.
The DM polls MIBs for the counters, so its possible the internal pointer is using the wrong MIB number.
Chris
