advanced-balance and weighting
aolabisi
I'd like to assign weights to services, but it says in the documentation that this works for weighted round-robin load-balance algorithm. will this work for an advance-balance scenario? i.e. will the config below work?
content Serv1-Rule
add service Serv-1
add service Serv-2 weight 2
add service Serv-3 weight 4
protocol tcp
redundant-index 1
port 80
advanced-balance arrowpoint-cookie
vip address 12.18.27.20
active
thanks,
dayo
Gilles Dufour
the way it works, is that the CSS tries to do an advanced-balance decision.
In your case, the CSS looks for a cookie ARPT=...
If this CSS can't make an advanced-balance decision (ie: there is no cookie) it will make a basic balancing decision.
This is where you can use a weight.
So, your config is good except that you didn't specify the basic loadbalancing method so the CSS will do roundrobin.
You need to configure something like 'balance weightedrr'
Gilles.
thanks Gilles. just so I'm clear, you're suggesting I have the following config?
content Serv1-Rule
add service Serv-1
protocol tcp
redundant-index 1
port 80
balance weightedrr
active
