AIM-IPS and Cisco WAAS
mlouis
Can you still use the AIM-IPS with Cisco WAAS? Is there a command to get waas traffic inspected?
Zach Seils
Level 7
Level 7
Mike,
AIM-IPS is not WAAS aware, to the best of my knowledge. So you basically want the AIM-IPS module to see the unoptimized (aka original) connection.
Zach
Hmm. How would you go about making sure that occured. We have a network module in the router along with the AIM-IPS. I am assuming we would only want to inspect traffic that was coming in on the ethernet interface before the waas saw it like you said.
Otherwise, could you write a rule in the AIM-IPS not to inspect traffic that was marked with the IP option that the WAEs use for autodiscovery?
What do you think the best way to approach this would be?
I need to test it out. Give me a few days.
Zach
