Any limit on interface numbers for WCCP interception
Joe Lau
May I know if there is any limit on the number of router interfaces for WCCP interception?
For example, there is an end site with primary and backup MPLS circuit, together with 5 or 10 LAN interfaces (in VLANs):
interface fa0/1
ip wccp 62 redirect in
interface serial1/0
interface vlan 5
ip wccp 61 redirect in
interface vlan 6
interface vlan 7
Joe
Marcin Latosiewicz
Joe,
If limit extists it will be per-platform. What are you using?
I'm not familair with the numbers but can dig it up for you (hopefully)
Marcin
Hi Marcin,
We are using ISRs like 3845/3825/2821/2811...
Joe
Joe,
For ISRs I was unable to find any such restriction internally or externally.
So I would say the only restriction that apply to WCCP are the ones mentioned by config guide:
http://www.cisco.com/en/US/docs/ios/ipapp/configuration/guide/ipapp_wccp_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1054493
Marcin
Hi Marcin,
Thanks a lot for the info!
Joe
