Ask the Expert: Understanding and Troubleshooting ACE Loadbalancer
ciscomoderator
Community Manager
Community Manager
Read the bioWith Sivakumar Sukumar
Welcome to the Cisco Support Community Ask the Expert conversation. This is an opportunity to learn and ask questions about configuration and troubleshooting the Cisco Application Control Engine (ACE) loadbalancer with Sivakumar Sukumar. The Cisco ACE Application Control Engine Module for Cisco Catalyst 6500 Series Switches and Cisco 7600 Series Routers is a next-generation load-balancing and application-delivery solution. A member of the Cisco family of Data Center 3.0 solutions, the module:
  • Helps ensure business continuity by increasing application availability
  • Improves business productivity by accelerating application and server performance
  • Reduces data center power, space, and cooling needs through a virtualized architecture
  • Helps lower operational costs associated with application provisioning and scaling
Sivakumar Sukumar is an experienced support engineer with the High Touch Technical Support content team, covering all Cisco content delivery network technologies including Cisco Application Control Engine (ACE), Cisco Wide Area Application Services (WAAS), Cisco Content Switching Module, Cisco Content Services Switches, and other content products. He has been with Cisco for more than 2 years, working with major customers to help resolve their issues related to content products. He holds CCNP and DCASI certification.
Remember to use the rating system to let Sivakumar know if you have received an adequate response.
Sivakumar might not be able to answer each question due to the volume expected during this event. Remember that you can continue the conversation on the Data Center sub-community discussion forum shortly after the event. This event lasts through August 24, 2012. Visit this forum often to view responses to your questions and the questions of other community members.
51 Replies 51
Hi Philip,
It has to be on the server itself, changing the default gateway on server to ACE ip should work here.
Siva
cscherb
Is or will ACE loadbalancer be capabel to deal with WebSocket protocoll as defined in RFC 6455 ?
How to deal with stickiness in this area ? My on lab experiments are showing that ip based stickniess is working with ACE software version A4(1.0) - but SessionID based stickiness is not possible.
Thanks for your question.
There are no immediate plans to support websocket on ACE and no roadmap available yet. I can tell from previous documented cases and from my personal experience on cases I've handled, there is a particular requirement which seems to be very important for WebSocket traffic.
As WebSocket requires stickiness, to enable all connections from a single user to stick to one server and is particularly effective (and sometimes strictly necessary) when the application requires user authentication, as otherwise,
traffic would be bouncing between two or more servers.
The type of stickiness that you would implement depends entirely on your network requirements.
Since ACE does not have any specific knowledge of the WebSocket protocols, it doesn't have the capability to do deeper protocol inspection but it seem to work for generic Connection based Level 3 and 4 load balancing which I believe you have already tested in your LAB.
You can also get in touch with your cisco internal contact, share the use case and more details to help assist on your requirement.
Siva
Akhtar Samo
Hi Siva,
Good to see the ACE discussion in the Experts Corner. My query is if there is any permanent fix to CSCsz65679 which causes ACE-20 to crash couple of times in a year ? I have noticed that RMA is not a fix for the problem neither the image upgrade. One of our customer had 10's of ACE-20s and neither RMA nor the upgrades fixed the 'NP Control Store Parity Error', so far they have observed around 10 total ACE-20 crashes on different modules in 3 years of time. The upgrades only reduces the crash frequency, probably due to explicit reload during upgrades which refreshes all the buffers.
I believe this might be an issue with the ACE-20 architecture ? similar issues have not been observed on ACE-30.
Akhtar
Hi Akhtar,
Sorry your customer had to experience too many crashes due to parity issue.
First let me expalain few things about SRAM. SRAM parity error presented in the core file is not due to a software issue. The issue is the result of a "bit-flip" within the SRAM itself which can occur as a result of environmental conditions. This "bit-flip" is rectified by a simple reboot of the system, which would occur with the generation of the core file.Our testing has shown that these type of issues can occur with very low frequency and if a particular module experiences a significantly higher failure rate and you are running a version which has all the possible workarounds for CSCsz65679 then a proactive RMA could be in order.
ACE20 is susceptible to this because of the way it uses SRAM to store  control information and packet data as  opposed to scratch-pad storage.  Almost any 1-bit flip will be detected as a parity error.
Unfortunately, SRAM's are very sensitive to light, dust, radiation,  shock, temperature,... so it is possible to get an SRAM parity error on  an healthy ACE.
You are right about ACE30, neither ACE4710 or ACE30 are affected by these issues as the design does not use sram  or nitrox.
Also note that we have EOL notice for ACE10/20:
http://www.cisco.com/en/US/prod/collateral/modules/ps2706/end_of_life_c51-674430.html
Siva
Hi Siva
i have two ace module , the standby one is reload sudden , how can i know the cause of this
I understand the standby ACE had an unexpected reload, do you see any crash info generated under "dir core:" after reload. If so please send those files to me to determine the reason for reload.
Otherwise you can raise a tac case and attach the following information for our analysis to determine the root cause.
1- 'show tech' on the switch
2- 'show tech' on the Admin context on the ACE
3- Logs on the switch covering the period when the reload happened.
4- Crash files from ACE located under "dire core:"
Let me know if you have any qusetions.
Siva
Hi Siva
I atteched the requied files , but regarding to the crash info , i didnt find crash info for the reload date ( 18 Aug 2012 11:41 PM )
Thanks Siva
Best Regards
Mohamed Abd EL Razik
Thanks for providing the data.
This looks like a silent reboot and SUP initiated the reload.
However the information doesn't really explain why it happened. Silent reboots are tricky as they don't leave much data to work with.
Here is the defect that we logged to track the silent reboot. With high probability a SW upgrade will be necessary as few bugs related to silent reloads have been fixed in A2(3.3) and current version is A2(3.5)) and then monitor device.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsy91540
There is an action plan to determine if this was traffic related L7 or management traffic ANM, XML, SNMP... which may be filling up the resources on ACE that caused the reload.
I can send you the detailed action plan via PM if reqiured.
Let me know if you have any questions.
Siva
Hi Siva,
Just a note on versions available. We recently appear to have run into the following Bug and had to downgrade to version A2(3.3) as removing our HTTP health probes did not seem like a workable solution for us.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtz47825
Once downgraded the paired modules stabalised (no longer re-loaded continuously). Both modules were in this state.
Just thought would provide some input.
Thanks.
Paul
Hi Paul,
Its good to know that the devices are stable now after downgrading to A2(3.3) and I am able to track down the TAC case you reported recently on this issue.
Looking into the bug, we had this issue reported mainly on version A2(3.5) in the past and we are working on reproducing the issue on different code versions to find out the reason for memory corruption.
We will have the fix after we successfully reproduce the problem and it has been updated with fixed version as A2(3.7).
Siva
Hi Siva
thanks for the information
kindly send me the detailed action plan to determine if this was traffic related L7 or management traffic ANM, XML, SNMP
Mohamed
Hi Mohamed,
Sent you the information via PM. Please check.
Siva
Thanks Siva for your support
Mohamed
Hi Siva,
I am attaching the running-config of the ACE which is currently under test in the lab.
As you can see VLAN - 20 is configured to the Client Side & VLAN-30 is configured on the server side.
I am not able to ping the ACE Interface IP address : 2092:dead:beef:cafe::3 from the Cisco Switch ( 7k ) whose interface is connected to the ACE on VLAN-20.
Any idea if this is normal behavior (or) is there any configuration mistake ?
Thanks !!
hostname ACE-4710
interface gigabitEthernet 1/1
  description *** Interface connecting to the UUT-Switch-7k (WS-C7206X) ***
  switchport access vlan 20
  no shutdown
interface gigabitEthernet 1/2
  description *** Interface connecting to the serverfarm ***
  switchport access vlan 30
  no shutdown
interface gigabitEthernet 1/3
  description *** UNUSED***
  no shutdown
interface gigabitEthernet 1/4
  no shutdown
access-list everyone  extended permit ip any any
access-list everyone  extended permit pim any any
access-list everyone  extended permit icmp any any
rserver host CNR
ip address 2092:dead:beef:cafe::90
inservice
rserver host CNR-IPv4
ip address 172.27.167.13
inservice
rserver host NMS
ip address 2092:dead:beef:cafe::999
inservice
serverfarm host LABSERVERS
rserver CNR
inservice
rserver CNR-IPv4
inservice
rserver NMS
inservice
! Layer-3 Traffic
class-map type management match-any MGMT
match protocol telnet any
match protocol https any
match protocol http any
match protocol xml-https any
match protocol ssh any
match protocol icmp any
! Layer-4 Traffic
class-map match-all slb-vip-LABSERVERS
match virtual-address 2092:dead:beef:cafe::1 any
! Layer-3 Class-Map defining source traffic. This traffic macthes server initiated
policy-map type management first-match MGMT_POLICY
class MGMT
permit
policy-map type loadbalance first-match LB_POLICY_LABSERVERS
class class-default
serverfarm LABSERVERS
policy-map multi-match CLIENT-VIPS_LABSERVERS
class slb-vip-LABSERVERS
loadbalance vip inservice
loadbalance policy LB_POLICY_LABSERVERS
loadbalance vip icmp-reply active
loadbalance vip advertise active
interface vlan 20
  description "Client Interface"
  bridge-group 1
  access-group input everyone
  service-policy input CLIENT-VIPS_LABSERVERS
  service-policy input MGMT_POLICY
  no shutdown
interface vlan 30
  description "Server Farm"
  bridge-group 1
  no shutdown
interface bvi 1
  ipv6 enable
  ip address 2092:dead:beef:cafe::3/64
  description "Client-Server Bridge Group"
  no shutdown
ip route ::/0 2092:dead:beef:cafe::2
username admin password 5 $1$Hh4K/EuN$J9mu8qUJbebWixnC5Wxpo1  role Admin domain
default-domain
username www password 5 $1$9yHPLof8$RZrtAsMV26WtOp/q8Ou8L.  role Admin domain de
fault-domain
On the 7200 switch which is connecting to the ACE :
interface GigabitEthernet0/3
description Connected to ACE-E1
no ip address
ip pim sparse-mode
ip igmp version 3
ip ospf 1 area 0
shutdown
duplex auto
speed auto
media-type rj45
negotiation auto
ipv6 enable
ipv6 ospf 1 area 0
interface GigabitEthernet0/3.20
encapsulation dot1Q 20 native
ipv6 address 2093:DEAD:BEEF:CAFE::2/64
ipv6 route 2092:DEAD:BEEF:CAFE::/64 2092:DEAD:BEEF:CAFE::1
I am setting it up for a basic management setup & later on progress to enable more functionalities in the ACE.
Please let me know if there are any mistakes (or) corrections which I might need to make in the configuration.
Thanks !
