Associating a Driver to Edge WAE's Printer
frankamankwah
I am trying to add a printer to my edge wae printer server but it for some reason I can not associate the drivers to the printer. Each time I follow the instructions in the cisco manual to associate the driver, I get a grayed out interface at the point where I have to choose PROPERTIES after I right click on the printer. Because of this, I can not select any driver to associate with.
Could someone please help me to resolve this issue?
Zach Seils
Level 7
Level 7
Frank,
Are you logged into the Windows workstation using the Print Admin credentials configured in the CM?
Zach
tmowinski
Enter the following command in the Run window on the Windows client:
\\wae_netbios_name
And you should first double click on the printers and fakses icon (you'll enter to this folder) and then right-click on the printers.
