Bandwidth reduction Clarification
oukpaka
I wish to clarify if the % reduction with or without passhrough traffic statisitics as viewed from central manager actually corresponds to actual percentage bandwidth reduction as seen by WAN bandwidth management tool like MRTG. FLUKE e.t.c because the setup i have does not correspond.
From the CM I have about 60% reduction meanwhile the the Fluke slight change in bandwidth and most if not all of the traffic is TCP and are monitored by the fluke.
Zach Seils
Level 11
Level 11
Obiora,
The % reduction shows the byte reduction for traffic seen by the WAE.
Zach
