Basic GSS configs
mchoo2005
Level 4
Level 4
Hi... I'm currently doing a design for a customer to deploy GSS on their network. This will be my very first GSS project, and I have a couple of basic config questions that aren't answered in the GSS docos:
Question 1:
The GSS Getting Started Guide mentioned that Eth0 is by default used for "inter-device communication". My question is, can the inter-device and keepalive communications share the same interface?
Question 2:
If inter-device and keepalive communications use different interfaces, should they connect to the same VLAN/subnet, or different ones?
Question 3:
Which interface is used to listen on/respond to clients?
Thanks in advance for your assistance.
Cheers
only 1 default gateway.
The GSS still has only 1 routing table, so it needs to be configured appropriately.
The command you mentioned earlier is more like to specify the source interface for sending internal data.
Gilles.
Gilles Dufour
Q1: yes - most people only uses 1 interface.
Q2: no - you can't put both interfaces in the same vlan.
Q3: The GSS listen on both interfaces.
Basically, you should only use eth0 unless this is a design with a lot of GSS [so a lot of internal traffic] and you want to dedicate an interface just for this internal traffic.
Gilles.
Thanks Gilles.
I have further questions though...
Now, if I want to use a dedicated interface for inter-device communications, that would mean the GSS will have 2 default gateways, wouldn't it? 1 for the inter-device comm port, and the other for the "normal data" port. Or the inter-device comm port only listens, but not transmits?
If all goes well, we may have to implement up to 8 GSS devices in total. So, I'm guessing that with this in mind, we should be using dedicated inter-device comm port. Is this correct?
Thanks.
Gilles.
