best way to remove CSM configuration from a switch
i.kiss
have a redundant pair of CSM , would like to move slave CSM to a new switch, what is quickest way to eliminate all configuration from this switch so the same can be installed on the new switch , without reloading the switch or causing any downtime to already existing connections through the master CSM.
sachinga.hcl
Level 4
Level 4
Martin Kyrc
Level 3
Level 3
On new slave CSM you must configure only minimum parts for redundancy (link sent sachin). All other is synced automaticaly.
