Bizarre ACE module behavior
Amadou TOURE
Level 4
Level 4
I configured a new serverfarm with leastconns predictor for two servers on our ACE module Version A2(2.3). Probes (show probes XX detail) to the servers are successful and both servers are operational (show serverfarm APPLI detail) but connections are directed only to one server.
When I deactived the server which is receiving the connections (no inservice), the ACE start to direct connection to the second server.
There are several serverfarm, configured the same way, that are Loadbalancing traffic as correctly.
Here is a sample of my config
serverfarm host TEST_443
predictor leastconns
  probe TEST_443_PROBE01
  rserver TEST_RS01 443
    inservice
  rserver TEST_RS02 443
    inservice
sticky http-cookie TEST_HTTPS TEST_443_STKY
  cookie insert
  timeout 720
  replicate sticky
  serverfarm TEST_443
probe http TEST_443_PROBE01
  port 443
  interval 20
  passdetect interval 60
  passdetect count 5
  request method get url /test
  expect status 302 302
  connection term forced
policy-map type loadbalance first-match TEST_L7PLB_HTTPS
  class class-default
    sticky-serverfarm TEST_443_STKY_SF
    insert-http X-Forwarded-Proto header-value "https"
    insert-http X-Forwarded-For header-value "%is"
policy-map multi-match SLB-HTTP-POLICY
class TEST_L4VIP_HTTPS
    loadbalance vip inservice
    loadbalance policy TEST_L7PLB_HTTPS
    loadbalance vip icmp-reply active
    loadbalance vip advertise active
    nat dynamic 1 vlan 202
    appl-parameter http advanced-options PERSIST
    ssl-proxy server TEST_SSL_PROXY_SERVER
PS : ACE uptime is 291days, could that impact ACE behavior ?
Thanks for any troubleshooting hints
Alex Rickard
Level 4
Level 4
Since you are using a  sticky serverfarm, the ACE will check the cookie (because cookie sticky is configured) and if it is still valid it will send it to the rserver that corresponds to the cookie. As long a the cookie is valid and the rserver is still up, the connection will be sent there. New connections without a cookie or a valid cookie will be sent to a rserver based upon the least connections algorithm.
-Alex
Alex Rickard
Level 4
Level 4
-Alex
Agreed Richard,
the problem is that all connections are sent to one server only, new connections are not split between the two servers.
thank you
Thanks Alex and stephen for your replies.
The config is OK, so is the ACE module. The problem was related to the way the customer tested its applications...he was not indeed clearing his browser cache and cookies before each connection as he was supposed to do.
stephen.stack
Level 9
Level 9
Looking at this on my phone but it looks like you L7 policy is referencing a sticky server farm that does not exist.
ie TEST_443_STKY_SF is incorrect name for sticky
If that's not it. Then check that the first server actually has a number of conns on it when a new connection is established. Sometimes when both servers have 0 conns - new incoming conns will always go to the first server
Stephen
Free network configuration management software at www.rconfig.com
========================== http://www.rconfig.com A free, open source network device configuration management tool, customizable to your needs! - Always vote on an answer if you found it helpful
