Cache Engine 500 and FrontPage Server Extensions
steve
Community Member
We just installed a Cache Engine 500 and now users are unable to authenticate using http with FrontPage for web publishing. Unfortunately I don't have a lot of time to search for the solution. Anyone know off hand what the solution is or where I could find it?
mdouhan
Community Member
Try and add the command "bypass auth-traffic all" that solved the problem for us
