Cache Engine Question
e.silva_2
Level 2
Level 2
I´m looking for a list of archives that the content engine can cache, Does exist someone?
Because I had problems to cache archives with this extension
*.js
*.asp
*.css
*.swf
Any Ideas why is not caching this type of files?
I did a HTTP-Tracer and in the header appears this:
GET /portal/content/Includes/scripts/usrInotes.js HTTP/1.1
Accept: */*
Referer: http://plazastag.com/tibco/Communities
Accept-Language: es-mx
Accept-Encoding: gzip, deflate
User-Agent: Mozilla/4.0 (compatible; MSIE 5.5; Windows NT 5.0)
Host: plazastag.com
Connection: Keep-Alive
HTTP/1.1 200 OK
Server: Microsoft-IIS/5.0
Date: Fri, 01 Nov 2002 16:12:46 GMT
Content-Type: application/x-javascript
Accept-Ranges: bytes
Last-Modified: Thu, 09 May 2002 04:09:09 GMT
ETag: "c8a9144ff7c11:a0e"
Content-Length: 957
smalkeric
Level 11
Level 11
A very small number of clients and servers do not interoperate correctly with web proxies. Some of the causes of interoperability problems include:
. Client software bugs (homegrown, non-commercial browsers)
. Server software bugs
. Applications which send non-HTTP traffic over HTTP ports as a way of defeating security restrictions
. Server IP authentication
It is quite possible that the cache engine is not caching the archives mentioned by you due to one of the above mentioned reasons.
If you would like to Check What Web Sites/URLs the Cache Engine Is Caching, please use this document:
http://www.cisco.com/warp/public/117/cache_engine/CE_sites.html
Here are the Cache Engine Transaction Log Analysis details:
http://www.cisco.com/warp/public/117/cache_engine/CE_logcodes.html
