Cache Engine with a private address
m.abdallah
Can I configure my CE590 with a private address ( for ex. 172.16.1.1 )
Should I translate this private address to a public address ?
The sample configuration in the below URL comment :
!---Important: If you configure the Cache Engine
!---with a private address, it must get!---translated to a public address. "
http://www.cisco.com/warp/customer/117/cache_engine/transparentconfig.htm
please advise me
Mohamed Abdallah
pknoops
Level 7
Level 7
Mohamed,
They key with this whole concept is simply that many external websites on the net will perform dns reverse lookups and that will be on the cache engine's ip address. If it is private, then it certainly must be natted somewhere in your network to a public ip address that resolves correctly on the internet. You would need to configure a PTR record in your dns for the cache engines ip address for this reverse lookup senario.
Pete Knoops
Cisco Systems
Pete,
Thanks for your help
Could you explain in more details ?
Should I configure a static NAT on the router for the CE ip address
OR use the PTR record in my DNS for the CE ip add. for the DNS reverse lookup ??
What if I give the CE a public IP address ? Do I need PTR record in my DNS for the CE ip address?
Mohamed Abdallah
Answer: In any event, you will need a PTR record configured in your DNS network for the CE ip address. This must be a public record so that the internet sites can do a reverse lookup. Best case senario for security is to configure static nat on the router with a public ip address that resolves to the internal private ip address of the CE
Answer: You can certainly do that and it does make things a bit easier. For security though, I recommend going with the private ip with nat upstream.
Pete..
