Capture filter in ACE
hdommath
Can someone clarify how the ACL wildcard mask works in the ACE30?. Ideally, wildcard mask of 0.0.0.0 should match all but what I am seeing is, it is treating is as match any.
Here is the scenario: I would like to capture all traffic between 1.1.1.1 and 2.2.2.2 and my ACL for the capture filer is
access-list capture line 8 extended permit ip 1.1.1.1 0.0.0.0 2.2.2.2 0.0.0.0
access-list capture line 16 extended permit ip 2.2.2.2 0.0.0.0 1.1.1.1 0.0.0.0
However, the capture file shows flows from the whole subnet. Why is that?
thanks
-Harish
8 Replies 8
Cesar Roque
Level 8
Level 8
Try with an ACL like this:
access-list cap line 8 extended permit ip host 1.1.1.1 host 2.2.2.2
access-list cap line 8 extended permit ip host 2.2.2.2 host 1.1.1.1
Cesar R
ANS Team
--------------------- Cesar R ANS Team
Ofcourse, that would work. I would like to know why the other syntax is not working. Functionally, it is same.
thanks
-Harish
Hi Harish,
From the documentation:
"For the source IP address netmask, the ACE  supports only standard subnet mask entries in an ACL. Wildcard entries  (for example, 0.0.0.15) and non-standard subnet masks are not supported."
"For the destination IP address netmask, the ACE  supports only standard subnet mask entries in an ACL. Wildcard entries  (for example, 0.0.0.15) and non-standard subnet masks are not supported. "
http://www.cisco.com/en/US/customer/docs/interfaces_modules/services_modules/ace/vA5_1_0/configuration/security/guide/acl.html#wp1005647
Cesar R
ANS Team
Aha!. That helps. Not sure why it is not implemented that way though (as in normal IOS).
-Harish
Cesar R
ANS Team
I also noticed that ACE converts the mask of 255.255.255.255 as "host". I would think it is treating it reverse but it is confusing.
Ex:
access-list TEST extended permit ip 1.1.1.1 255.255.255.255 2.2.2.2 255.255.255.255
is converted to this (in the running config).
access-list TEST line 8 extended permit ip host 1.1.1.1 host 2.2.2.2
I think I can see what the issue is. In ACE it is not the wildcard mask, but the subnet mask. So 255.255.255.255 is match all and 0.0.0.0 is match any.
Yes, correct.
Cesar R
ANS Team
