CE 565 will not boot
matthoulden
Community Member
When I start up my content Engine the system does all its usual checks and starts the boot process. I then get to the ACNS startup and just hangs. See output below:
Application and Content Networking System Software (ACNS)
Copyright (c) 1999-2003 by Cisco Systems, Inc.
Application and Content Networking System Software Release 5.1.5 (build b2 Mar 3
0 2004)
INIT: Entering runlevel: 3
Nodemgr started!
Dec 2 16:50:15 (none) %CE-SYS-3-900000: ..MP-BIOS bug: 8254 timer not connected
to IO-APIC
Dec 2 16:50:15 (none) %CE-SYS-3-900000: wccp: v1.00 (20000327), debug=0
check-parameter-packet-v2: short read on /tmp/127.sect: Success
BOOT-100: no v2 pp, continuing normal booting
/ruby/bin/apply-parameter-packet-v4: short read on /tmp/127.sect: Success.
BOOT-100: no v4 pp, continuing normal booting
From this point it just hangs
Thanks in advance
Matt.
mchin345
Level 11
Level 11
I think you need to connect to the Content Engine via the serial port using a DB9 connector and a rollover cable, then connect to a PC via console port. On the HyperTerminal settings use the default values (bits per second 9600, data bits 8, parity none, stop bits 1, flow control none).
gid
Community Member
I'm not sure what the problem might be, exactly, but my guess is it's a ddts that's been fixed. If you're still having this problem, I would suggest getting a newer 5.1.x or 5.2.x flash image file (ACNS-.sysimg from the sw center) and installing that. You can install it from the rescue image by interrupting the bootloader before it loads the regular image (type "***" at the console when prompted). Do a search in the ACNS documentation for "rescue image" for the exact procedure. The procedure will ask you to enter CE IP, netmask, interface to use, default gateway, an address for an FTP server to get the *.sysimg file from, and FTP server username/password.
matthoulden
Community Member
Thanks for the advice but with futher investigation I have found that the content engine has a faulty flash disk.
I have spoken to cisco and they have agreed to replace the content engine with a new one.
