CE590 http Saving
m.abdallah
I installed Cisco Content Engine 590 on ISP network
How can I test the performance of the CE590 ??
What is the accepted saving percentage ?
sh ver
Copyright (c) 1999-2001 by Cisco Systems, Inc.
Cisco Content Engine Software Release 3.11 (build FCS May 30 2001)
Version: ce590-cache-3.1.1
Compiled 09:49:25 May 30 2001 by bbalagot
Compile Time Options: PP
System was restarted on Thu Oct 31 11:39:00 2002.
The system has been up for 2 hours, 5 minutes, 42 seconds.
content#
content#sh staticontent#sh statistics htt saving
Statistics - Savings
Requests Bytes
Total: 123145 805553899
Hits: 16533 44281031
Miss: 106612 761272868
Savings: 13.4 % 5.5 %
My router show my the following statistics :
Router#show ip wccp web-cache
Global WCCP information:
Router information:
Router Identifier: 62.32.60.254
Protocol Version: 2.0
Service Identifier: web-cache
Number of Cache Engines: 1
Number of routers: 1
Total Packets Redirected: 882029
Redirect access-list: -none-
Total Packets Denied Redirect: 0
Total Packets Unassigned: 0
Group access-list: -none-
Total Messages Denied to Group: 0
Total Authentication failures: 0
Router#show ip wccp web-cache detail
WCCP Cache-Engine information:
IP Address: 62.32.60.250
State: Usable
Initial Hash Info: 00000000000000000000000000000000
Assigned Hash Info: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
Hash Allotment: 256 (100.00%)
Packets Redirected: 882673
Connect Time: 02:14:08
I think, the caching performance is not good
What do you suggest ??
Mohamed Abdallah
19 Replies 19
Pete,
Thanks for your help
The CE590 saving performance is 30% : 40%
i think this is a good performance
I have a question regarding the CE590
If the internet link is down, and the client open its browser
Should he get the web site from the CE ( browse the cached site ) while the internet link is down ?
Mohamed Abdallah
Pete,
My setup is :
PIX firewall connected between the internal network and the inernet.
All clients & Servers are on the inside network and there are three ISA proxy servers (insdie of the PIX ) which all clients browseres them it for http internet connection.
CE 590 & main router (3661) connectedd the outside of the PIX
Main router 3661 FastEther connected to ouside network of the PIX ( CE 590 on this network also ), and 3661 Serial is connetced to internet.
CE 590 ip address is public address
PIX is doing NAT translation from internal private addresses ( 10.x.x.x ) to public addresses
PTR record with content.uruklink.net to public ip address of the CE590
My CE configuration is :
hostname content
ip domain-name uruklink.net
interface FastEthernet 0/0
ip address 62.32.60.250 255.255.255.0
exit
interface FastEthernet 0/1
shutdown
exit
ip default-gateway 62.32.60.254
ip name-server 62.32.60.1
wccp router-list 1 62.32.60.254
wccp web-cache router-list-num 1
wccp version 2
In the Router configuration :
ip wccp web-cache
ip cef
and in the Fastethernet connect to PIX outside and CE 590
ip route-cache same-interface
and in the Serial connect to internet
ip wccp web-cache redirect out
Do I have anything missing or wrong in my CE and router configuration ?
Mohamed Abdallah
pknoops
Level 7
Level 7
I should also add to my other comments that you would certainly be better off running 4.1.2 software on the CE as this is much cleaner code with respect to WCCP. I would have to say that this is critical !!
Pete..
Pete,
The latest ver. of CE on Cisco web is 3.11
where can I get the ver. 4.1.2 ???
Mohamed Abdallah
Pete,
i have notice that there was NO cfs on my disks
so I created cfs by disk manufacture disk01 cfs command
now my disks :
content#show disk-part disk00
Disk size in 512 byte blocks: 35566448
num: type start size status
0: SWFS 32 3145728 System Reserved
1: SYSFS 3145760 7113289 mounted at local1
2: NONE
3: NONE
Free disk space: 25307431 blocks (12357 M)
content#show disk-part disk01
0: CFS 32 35566448 mounted
1: NONE
2: NONE
3: NONE
Free disk space: 0 blocks (0 M)
content#
**** The Saving percentage increase but still have a lot of bypass ****
content#show stat http sav
Requests Bytes
Total: 7055526 52055575500
Hits: 1680348 6605533706
Miss: 5375178 45450041794
Savings: 23.8 % 12.7 %
content#
content#show bypass
Total number of HTTP connections bypassed = 192678
Connections bypassed due to system overload = 0
Connections bypassed due to authentication issues = 0
Connections bypassed due to facilitate error transparency = 192678
Connections bypassed due to static configuration = 0
Total number of entries in the bypass list = 35
Number of Authentication bypass entries = 0
Number of Error bypass entries = 35
Number of Static Configuration entries = 0
content#
content#
content#
content#show bypass list
Client Server Entry type
62.32.60.40:0 66.180.230.128:80 server-error
62.32.60.41:0 66.180.230.143:80 server-error
62.32.60.41:0 207.68.176.190:80 server-error
62.32.60.40:0 208.184.29.70:80 server-error
62.32.60.41:0 199.104.132.230:80 server-error
62.32.60.41:0 216.136.131.30:80 server-error
62.32.60.41:0 66.180.230.42:80 server-error
62.32.60.40:0 213.253.55.27:80 server-error
62.32.60.41:0 209.157.71.50:80 server-error
62.32.60.41:0 217.66.226.9:80 server-error
62.32.60.41:0 216.239.37.102:80 server-error
62.32.60.40:0 207.46.196.108:80 server-error
62.32.60.40:0 193.232.242.71:80 server-error
62.32.60.41:0 213.219.2.46:80 server-error
62.32.60.41:0 195.188.170.32:80 server-error
62.32.60.40:0 66.180.230.135:80 server-error
62.32.60.41:0 207.46.196.108:80 server-error
62.32.60.40:0 66.179.17.168:80 server-error
62.32.60.41:0 198.65.220.224:80 server-error
62.32.60.40:0 152.163.208.185:80 server-error
62.32.60.41:0 208.184.29.50:80 server-error
62.32.60.40:0 216.27.95.48:80 server-error
62.32.60.40:0 63.88.212.80:80 server-error
62.32.60.40:0 81.9.32.2:80 server-error
62.32.60.41:0 152.163.208.185:80 server-error
62.32.60.40:0 66.180.230.110:80 server-error
62.32.60.40:0 165.193.123.40:80 server-error
62.32.60.41:0 64.55.105.88:80 server-error
62.32.60.41:0 216.239.33.100:80 server-error
62.32.60.41:0 216.244.111.206:80 server-error
62.32.60.40:0 216.32.242.251:80 server-error
62.32.60.41:0 209.54.220.67:80 server-error
62.32.60.41:0 213.171.193.15:80 server-error
62.32.60.41:0 216.239.51.106:80 server-error
62.32.60.41:0 204.71.61.248:80 server-error
62.32.60.41:0 66.180.230.41:80 server-error
62.32.60.41:0 209.71.218.253:80 server-error
Do you have suggestion ??
Mohamed Abdallah
