cisco 4506 PBR failure detection solution ?
chia hao chang
hi all
I use PBR to redirect traffic to wae in cisco 4506
4506 IOS ver is enterprise12.2(46) SG
supervisor 4
in waas configuration guide
when use PBR to redirect traffic to wae
it have 3 method to verify wae is available
but the sample configuration are all in router environment
it use command "set ip next-hop verify-availability 1.1.1.1 track 1"
to verify wae status
but
in 4506, it has not command "verify-availability"
although, I use ip sla to track wae status
cisco 4500 series is common use in small business
could anyone please share the solution to solve this question with me
thanks
Bhavin Yadav
Hi Chia,
You may want to take this question in Lan Switching Routing forum as it is related more to the Lan Switching / Routing commands and references..
https://supportforums.cisco.com/community/netpro/network-infrastructure/switching
About the WAE setup, all it cares in line setup is to pass the traffic in transparent way. In the WCCP / PBR setup, all it does is receives the traffic and sends it back out to the origin tunnel interface / default gateway depending on your configuration.
Hope this helps.
Regards.
