Cisco ACE 30 src NAT issue
Richard Tapp
I have run src NAT from one VLAN to other VLAN on the ACE OK for years. Now I need to ensure the outbound flow (to internet destination) from two servers is src natted. The inbound LB flow to the VIP (of the two servers) 10.100.60.10 tcp/25 is fine.
This is how I would normally do it, but it is not nating the real IPs.
access-list XX-XCH2010-EDGE line 20 extended permit ip any any
access-list XX-ACEDMZ-VIP line 10 extended permit ip any any
class-map match-all XX-XCH2010-EDGE
  2 match virtual-address 10.100.60.10 tcp eq smtp
class-map match-any XX-XCH2010-EDGE-REALS
  2 match source-address 10.100.72.10 255.255.255.255
  3 match source-address 10.100.72.11 255.255.255.255
policy-map type loadbalance first-match XX-XCH2010-EDGE
  class class-default
    serverfarm XCH2010-EDGE-Servers
policy-map multi-match XX-ACEDMZ-VIPS
  class XX-XCH2010-EDGE-REALS
    nat dynamic 1 vlan 172
    loadbalance vip inservice
    loadbalance policy XX-XCH2010-EDGE
    loadbalance vip icmp-reply
interface vlan 160
  description XX-ACEDMZ-VIPS
  ip address 10.100.60.4 255.255.254.0
    access-group input XX-ACEDMZ-VIP
  service-policy input XX-ACEDMZ-VIPS
interface vlan 172
  description XX-XCH2010-EDGE
  ip address 10.100.72.4 255.255.254.0
  access-group input XX-XCH2010-EDGE
  nat-pool 1 10.100.60.10 10.100.60.10 netmask 255.255.254.0 pat
Amjad Hashim
Hi Richard,
As far as i understand the src NAT in ACE is applied to outbound interface, so i think you should move your nat pool statement to VLAN 160 and also change your nat application under service policy to vlan 160. Hopefully that will resolve the issue for you.
Amjad Hashim.
