Cisco ACE 4710 - load balancing base on URL pattern
josemvigueras
We are currently looking into doing load balancing request base on URL pattern and not just domain name or IP.
Scenario:  We have a VIP define for HTTP traffic and the request are been  sent to a server farm VFarm01, however we will like to send http request  to another server farm VFarm02 if URL pattern is: http://api.m123.com/v1
•      http://api.m123.com/v1     will be sent to VFarm01
•      http://api.m123.com/v2     will be sent to VFarm02
Can you please advise if this behavior possible on:
Cisco ACE 4710 (A3).
Version A3(2.2)
ciscocsoc
Level 4
Level 4
The Cisco example at http://www.cisco.com/en/US/products/hw/modules/ps2706/products_configuration_example09186a00809c3048.shtml shows hoe to combine Layer 4 and Layer 7 classmaps to achieve what you need.
Cathy
ciscocsoc
Level 4
Level 4
Cathy
Thank you very much, that exactly what I need.
I was no able to find that example of configuration.
Regards.
