Cisco ACE 4710 TCP Normalization
robert.horrigan
Level 2
Level 2
I've run into so many issues with the ACE affecting TCP traffic - ie not allowing larger window files, disconnecting FTP sessions, etc.  Is there a way
to disable normalization all together and make the ACE act like a router that load balances?  If so can you
please provide a config example and what the issues would be with implementing this?
litrenta
Level 3
Level 3
disabling normalization is done under the interface  with "no normalization"
The issues associated with doing this could be:
asymetric traffic would be allowed
connections could be opened with non-syn packets in the case of TCP
sequence numbers would not be randomized
litrenta
Level 3
Level 3
Thanks!
