Cisco ACE Module CPU&Memory Resource Allocation
francisco_1
Level 11
Level 11
Can i allocation CPU and Memory resoruces to each virtual context on the ACE module. If one conext ultilizes high CPU or memory, does that affect other context?
Collin Clark
Per the datasheet-
Virtual devices provide a means for creating resource segmentation and isolation, allowing the Cisco ACE appliance to act as if were several individual virtual appliances within a single physical appliance. Virtual devices enable organizations to provide defined levels of service to up to 20 business organizations, applications, or customers and partners from a single Cisco ACE appliance.
Complete separation of the following:
• Configuration files
• Management interfaces
• Application rule sets
Customized, guaranteed resources per application for the following:
• Throughput
• Connections per second
Capability to limit and manage the allocation of the following Cisco ACE resources:
• ACL memory
• Buffers for syslog messages and TCP out-of-order (OOO) segments
• Concurrent connections (traffic through the Cisco ACE)
• Management connections (traffic to the Cisco ACE)
• Proxy connections
• Setting of resource limit as a rate (number per second)
• Regexp memory
• SSL connections
• Sticky entries
• Static or dynamic network address translations (xlates)
You don't allocate CPU/memory, but you can set limits on resources listed above which generally map back to CPU/memory utilization. The CPU/memory are "global".
Hope that helps.
