Cisco ACE rewrite question.
tdzb
Here is the setup. User hits a VIP via https. The ACE terminates the SSL and forwards it to the server on port 80. The server has a agent installed (siteminder) that sees the user is not logged in and redirects them to the authentication server. When the user logs in it redirects them to the original URL using http instead of https. I've tried using many different rewrites to get this to https: but nothing seems to work. I did a trace and this is the response from the rserver that redirects them to the logon server.
http://stgcontent.abc.com/at_abc/navigation/ABCConnectionLogin.asp?TYPE=33554433&REALMOID=06-cc299e90-76cc-4efe-b68e-c8bb3c61cf7f&GUID=&SMAUTHREASON=0&METHOD=GET&SMAGENTNAME=$SM$zWep8n4YLnnpJM%2f6%2bpFLe6TuVYSVKoEJMW8bEk42PH2pllUc9k%2b2%2fJGM3oOLNqEf...http%3a%2f%2fL17SVAPLUS01%2eABC%2ecom%2fPLUSWEB%2fStartPage%2easpx
So after the user logs on he is sent back to
http://l17svaplus01.ABC.com/PLUSWEB/StartPage.aspx
instead of'
https://l17svaplus01.ABC.com/PLUSWEB/StartPage.aspx
any ideas?
Surya ARBY
Level 4
Level 4
Hi.
Unfortunately when it goes to advanced rewrite rules the ACE has limited capability. I guess the best you can do is an ssl rewrite
action-list type modify http urlrewrite   ssl url rewrite location "www\.cisco\.com"
but I'm afraid it will look only to the first bytes of the content of the location field, if the URL you need to rewrite is embedded in a longer string of character the parser will not probably detect it.
I need to understand the architecture, correct me if I'm wrong.
1 - a user comes in HTTPS and hits the VIP using HTTPS on port 443
2 - the ACE forwards the request in clear http on port 80
3 - the siteminder agent detects the user is not logged in and sends a 302 redirect to an authentication server on another URL
4 - the user reaches the authentication server directly (or by using a VIP on the ACE ?) in HTTP or HTTPS
5 - the authentication server authenticates the client and then sends a 302 redirect with an "http://" link in the Location field
Am I wrong somewhere ?
Can you send a pcap trace of the last redirection which causes the issue ?
Maybe some Cisco guy can help, is it possible to match a part of the URL in the Location field and replace it by another string of character ?
Yeah I've scoured throught the forum looking at other examples and tried header rewrites and ssl rewrites with no luck.
You are correct on the architecture.
4. The user goes to the authentication server using https to a VIP.
The monster I pasted in the first post is the location field of the 302 redirect. Which takes you to the authentication/logon page. Once they login I guess it takes the url in that jumbled mess and turns it into the http link and redirects the user to that page intead of the https link.
I tried matching on http%3a in the link as well as other various fields in that link but doesnt seem to be able to match on it.
According to the doc it seems to be possible by using some parameters (%1, %2) :
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA4_2_0/configuration/slb/guide/classlb.html#wp1563764
host1/Admin(config)# action-list type modify http HTTP_MODIFY_ACTLIST
host1/Admin(config-actlist-mod)# header rewrite response Location header-value STRANGE-REGEX-HERE replace %1https://l17svaplus01[.]ABC[.]com%2
I believe your expression is not triggered because when the URL is parsed by the ACE it should be transformed by some normalization engine and then sent to the matching rule
What does happen if you make a replacement rule with a direct target of "https://l17svaplus01.ABC.com/PLUSWEB/StartPage.aspx" in the Location field instead of trying to rewrite the original response from the authentication server ?
Maybe someone here has played with this type of config more than me. And I don't have the box to test currently.
parveesm123
Try to use server redirect
rserver redirect RSERV-REDIRECT
webhost−redirection https://%h%p 301
inservice
serverfarm redirect SRFRM-REDIRECT
rserver RSERV-REDIRECT
inservice
policy−map type loadbalance http first−match P7-REDIRECT
class class−default
serverfarm SRFRM-REDIRECT
class-map match-all C3-REDIRECT
2 match virtual-address x.x.x.x tcp eq www
policy-map multi-match P4-POLICY
class C3-REDIRECT
loadbalance vip inservice
loadbalance policy P7-REDIRECT
loadbalance vip icmp−reply active
Can you try using this.
thanks,
Parvees M
