Cisco ACE with ACS5.0
helsayed78
Guys,
Is there a way that I can configure authentication using ACS 5.0 to access a certain server farm group only for a specific user?
2 Accepted Solutions
Yes you could using roles & domains. you would initially have to configure a domain on the ACE and add the relevant serverfarm to it.
Then in ACS configure the policy for authentication & authorization and under the Shell Profile / Custom Attributes section add an attribute of shell: with Value of , similar to what I have below for my environment (I just have a role of Admin and the default domain in mine).  Then you can test by logging in and issuing the 'show users' command to verify (or check ACS Tacacs/Radius logs)
To match against an AD attribute, firstly you would need to configure ACS to see your windows domain as a valid External Identity store then your authorization policy would need to make use of what ACS calls 'Group Mappings'.
This is where you tell ACS what attribute to look for in AD and what the resultant internal ID group is.  This internal ID group is then used in your authorization policy
If you need any more information, take a look at the ACS guides or ask the experts over in the Security/AAA section.
Thank you so much , but how can I match this with the group on the AD since I am using the external DB method not the internal?
Thanks Mick, it is working like charm
