Cisco content switch capacity stats
Michael.E.Reid_2
Community Member
Hi, I know there is a 200,000 limit on concurrent connection on our CSS devices, but is there any way to see how the CSS has behaved historically in terms of the most concurrent connections there has been on the box at a time, average concurrent connections?
Or do you know if there is a MIB we can receive and graph on?
cheers,
Mike
Michael.E.Reid_2
Community Member
Doing some more digging, from the 'Show IP statistics' command is this the amount of max concurrent connections the box has seen. (in BOLD and RED text below)
lamsdc1cs003> show ip statistics
IP Statistics - SP Slot 1, Subslot 1:
UDP Statistics:
Input Datagrams:             81,467,201 Output Datagrams:            81,467,201
No Port Errors:                       0 Input Errors:                   104,620
IP Fragments:                       110
TCP Statistics:
Retransmit Algorithm              other Min Retransmit Time:                500
Max Retransmit Time:             15,000 Max TCP Connections:             32,768
Active Opens:               302,647,530 Passive Opens:            2,831,374,249
Failed Attempts:             49,337,843 Resets:                     966,887,218
Established Conns:        2,392,842,101 Input Segments:           1,112,029,840
Output Segments:          2,452,796,476 Retransmit Segments:            208,657
Input Errors:                    69,601 Output Resets:               29,953,594
IP Fragments:                    40,642 VIP Unavail Reset:                    0
