Cisco CSS Load Balancer Certificate upload in Stanby box
jchakrabarty
Kindly help me to get the exact syntax to push the certificate to the standby CSS load balancer.
I have uploaded the certificate in primary and working fine.
CSS1# rcmd 10.10.10.1 "copy ssl ftp FTP import test2.cer DER "Password""
%% Text not quoted.
Arun V S
Kanwaljeet Singh
Hi Arun,
This is the command:
copy ssl [protocol] ftp_record [import filename [format] "password" {"passphrase"}|export filename2 "password"]
If you are able to import on CSS primary, you should be able to do it for standby too.
Kanwal
Note: Please mark answers if they are helpful.
