Cisco WAAS SSL enabled - Internet sites not working
Prabhu S
I have implemented Cisco WAVE 594 - 2 Devices in datacenter (one is central manager and other is Core Edge WAVE) and also deployed WAVE 7541 in Zonal Offices for WAAS Optimization. At present, i am able to see the optimization traffic between Datacenter and Zonal offices. Also i have installed SSL certificate, private key in Core WAVE (datacenter) and SSL certificate, Private key in Zonal Edge WAVE & initialize the passphrase in Central manager. I am able to see the SSL optimization traffic also. Only issue is when i enable SSL in all Cisco WAVE devices.
When Zonal office want to access the internet sites request will send to datacenter where proxy server is in place behind the Core WAVE devices. Users are in Zonal office not able to access the https sites like axisbank or icicibank. They are getting the homepage of that sites session timeout will be happening when SSL enabled in Cisco WAVE devices. Is there any fix for this issue.
Regds...
Prabhu
adrrojas
Hi Prabhu,
If your connections go towards a proxy server, do HTTPS connections use a different port(instead of 443)?
If this is the case, do you have a Custom policy configure for this?
Does your WAAS count with a DNS server configure and able to reach it?
Kindly advise.
Hi Adriana,
HTTPS connection use the same port for http traffic i;e port 8080 for proxy.
When we enable TFO + LZ compression for all the traffic going towards proxy, SSL sites are opening. But when we enable TFP + LZ + DRE  https sites are not opening.
Would you guide with how to configure a separate policy for https traffic tunnel through http and destined to proxy server.
Thanks in advance.
Hi Prabhu,
If both HTTP and HTTPS traffic use the same port towards the proxy, we cannot configure a different policy for each. This is not a recommended setup. Can you change the port for HTTPS connections?
Remember that WAAS cannot treat the traffic in the same way, are the SSL connections matching the default HTTP clasifier?
Which policy do you use for testing (Adding and Removing DRE)? Does this policy have the HTTPAO enable?
You mentioned at the beginning of the post that you enabled SSL accelerated service, did you upload Server certiifcate and Key for the failing domains? If the clients are failing to open public domains you may check on the DNS responses.
Eventough your traffic uses the same port for HTTP and HTTPS connections,  WAAS is capable to identify the secure connection and will try to hand off the connections to the SSLAO , the SSLAO needs a Domain resolution to look if it has the specific domain configured within a SSL accelerated service, if its not the case, then the SSL connection will be treated as the 443 clasifier (TFO only). If the DNS response takes long to response, the HTTP will report that failed handing the connection to SSLAO.
Kindly let me know which policy and its configuration is your SSL connection matching, you can identify this with the following command:
sh stat conn | inc :8080
sh stat conn conn-id < --- This command when you identify the SSH connections on the sh stat conn, the conn-id is the number at the beginning , Left hand.
Hi Adriana,
Thanks for your response.
Ans : I have made a seperate customized policy in WAVE device with TFO+DRE+LZ. Now all users are able to access the https site without any issue.
Ans : One more issue i faced after installed the SSL Certificate & Key in WAVE where server is residing. Enabled full optimization in policy for SSL, Central manager enabled passphrase key and Core WAVE device enabled SSL features, enabled full optimization in policy for SSL.
I am able to see the optimization traffic for the server ip 10.111.0.14 both http(80) and https(443)
Server IP : 10.111.0.14
I hope after installed the SSL certificate in WAVE device all traffic to 10.111.0.14 must be 443 but seeing same server 10.111.0.14 getting http traffic 80.
Please find the logs for your reference.
WAVE-7541#sh statistics connection | in TSDL
416014    10.97.139.157:1127       10.111.0.14:443 e4:d3:f1:d0:75:00 TSDL  00.0%
WAVE-7541#sh statistics connection conn-id 416014
Connection Id:            416014
    Peer Id:                  e4:d3:f1:d0:75:00
    Connection Type:          EXTERNAL SERVER
    Start Time:               Mon Jan 14 13:43:30 2013
    Source IP Address:        10.97.139.157
    Source Port Number:       1127
    Destination IP Address:   10.111.0.14
    Destination Port Number:  443
    Application Name:         SSL
    Classifier Name:          HTTPS
    Map Name:                 basic
    Directed Mode:            FALSE
    Preposition Flow:         FALSE
    Policy Details:
           Configured:        TCP_OPTIMIZE + DRE + LZ
              Derived:        TCP_OPTIMIZE + DRE + LZ
                 Peer:        TCP_OPTIMIZE + DRE + LZ
           Negotiated:        TCP_OPTIMIZE + DRE + LZ
              Applied:        TCP_OPTIMIZE + DRE + LZ
    Accelerator Details:
                Configured:   None
                   Derived:   None
                   Applied:   SSL
                      Hist:   None
                                    Original            Optimized
    Bytes Read:                          922                 1061
    Bytes Written:                       519                 1967
    Total Reduction Ratio: 00.000%
DRE : 416014
Conn-ID: 416014 10.97.139.157:1127 -- 10.111.0.14:443  Peer No:  0 Status: Activ
e
Open at 01/14/2013 13:43:30, Still active
Encode:
   Overall: msg:          1, in:    204 B, out:    212 B, ratio:   0.00%
       DRE: msg:          1, in:    204 B, out:    244 B, ratio:   0.00%
DRE Bypass: msg:          0, in:      0 B
        LZ: msg:          1, in:    244 B, out:    212 B, ratio:  13.11%
LZ Bypass: msg:          0, in:      0 B
    Avg latency:      0.089 ms, Avg msg size:    204 B
  Message size distribution:
    0-1K=0%  1K-5K=0%  5K-15K=0%  15K-25K=0%  25K-40K=0%  >40K=0%
Decode:
   Overall: msg:          1, in:    255 B, out:    211 B, ratio:   0.00%
       DRE: msg:          1, in:    265 B, out:    211 B, ratio:   0.00%
        LZ: msg:          1, in:    255 B, out:    265 B, ratio:   3.77%
    Avg latency:      0.050 ms, Avg msg size:    211 B
Connection details:
  Encode bypass due to:
      last partial chunk: chunks: 1,  size:     64 B
  Nacks: total 0
  R-tx: total 0
  Encode LZ latency:      0.051 ms per msg, avg msg size:    244 B
  Decode LZ latency:      0.021 ms per msg, avg msg size:    265 B
  Cache write detail:
  Disk size saving due to unidirectional mode:      0 B
TFO : 416014
e
  Conn-Type:    EXTSERVER             Policy: DRE+LZ
  EOT state:
     Write: req: N, ack: N,  Read: req: N, ack: N
  Socket states
     AO : read-shut: N,  write-shut: N,  close: N, fd: 2451
          read-inKQ: Y,  write-inKQ: N,  choke: N, envoy: Y
     WAN: read-shut: N,  write-shut: N,  close: N, fd: 2450
  DRE Classification:  local: BI, remote: BI, applied: BI
  DRE hints:
     local   : DRE mode: 0 latency: 0 plz-off: 0, lz-off: 0, dre-off: 0
     remote  : DRE mode: 0 latency: 0 plz-off: 0, lz-off: 0, dre-off: 0
     active  : DRE mode: 0 latency: 0 plz-off: 0, lz-off: 0, dre-off: 0
  Scheduler:    class_id: 0   dscp: 0
                             Encode-Flow             Decode-Flow
  Read
     Total bytes:                  204                       316
     Total number:                   1                         3
     Average size:                 204                       105
     Schd latency(ms):            0.02                      0.03
     Stop latency(ms):            0.00                      0.00
     Read latency(ms):            0.01                      0.01
     Flow-ctrl stop:                 0                         0
     Peer-choke:                     0                         0
     Processed ack frames:                                     1
  Decoder pending queue:
     Maximum size:                                             0
     Current size:                                             0
     Average size:                                             0
     Flow-ctrl stop:                                           0
  Encode/Decode:
     Number of calls:                1                         1
     Latency(ms):                 0.09                      0.05
     Send data/ack frames:           1                         1
  Writer pending queue
     Maximum size:                   0                         0
     Current size:                   0                         0
     Average size:                   0                         0
     Flow-ctrl stop:                 0                         0
  Write
     Total bytes:                  289                       211
     Total number:                   3                         1
     Avergage size:                 96                       211
     Latency(ms):                 0.00                      0.00
SSL : 416014
   Time Statistics were Last Reset/Cleared:                           Mon Jan 14
13:43:30 2013
   Total Bytes Read:                                                  0
   Total Bytes Written:                                               0
   Memory address:                                     0x7c3ce0
   LAN bytes read:                                     922
   Number of reads on LAN fd:                          4
   LAN bytes written out:                              519
   Number of writes on LAN fd:                         3
   WAN bytes read:                                     1061
   Number of reads on WAN fd:                          29
   WAN bytes written out:                              1967
   Number of writes on WAN fd:                         9
   LAN handshake bytes read:                           677
   LAN handshake bytes written out:                    274
   WAN handshake bytes read:                           647
   WAN handshake bytes written out:                    1075
   AO bytes read:                                      211
   Number of reads on AO fd:                           1
   AO bytes written out:                               204
   Number of writes on AO fd:                          1
   DRE bytes read:                                     289
   Number of reads on DRE fd:                          3
   DRE bytes written out:                              316
   Number of writes on DRE fd:                         3
   Number of renegotiations requested by server:       0
   Number of SSL renegotiations attempted:             0
   Flow state:                                         0x00080000
   LAN work items:                                     1
   LAN conn state:                                     READ
   LAN SSL state:                                      SSLOK (0x3)
   WAN work items:                                     0
   WAN conn state:                                     READ
   WAN SSL state:                                      SSLOK (0x3)
   W2W work items:                                     1
   W2W conn state:                                     READ
   W2W SSL state:                                      SSLOK (0x3)
   AO  work items:                                     1
   AO  conn state:                                     READ
   DRE work items:                                     1
   DRE conn state:                                     READ
   Hostname in HTTP CONNECT:
   IP Address in HTTP CONNECT:
   TCP Port in HTTP CONNECT:
WAVE-7541#sh statistics connection optimized
395996    10.98.63.177:51553        10.111.0.14:80 e4:d3:f1:d0:75:d4 THDL  74.3%
Connection ID : 395996
WAVE-7541#sh statistics connection conn-id 395996
Connection Id:            395996
    Peer Id:                  e4:d3:f1:d0:75:d4
    Start Time:               Mon Jan 14 12:59:43 2013
    Source IP Address:        10.98.63.177
    Source Port Number:       51553
    Destination Port Number:  80
    Application Name:         Web
    Map Name:                 basic
    Policy Details:
                Configured:   HTTP
                   Derived:   HTTP
                   Applied:   HTTP
                      Hist:   None
                                    Original            Optimized
    Bytes Read:                        10467                 2914
    Bytes Written:                      8651                 1991
    Total Reduction Ratio: 74.344%
HTTP : 395996
12:59:43 2013
   Total Bytes Read:                                                  8651
10467
   Total Bytes Written:                                               8651
10467
   Total Bytes Buffered:                                              0
   Total Internal Bytes Read:                                         164
   Total Internal Bytes Written:                                      164
   Bit Flags for I/O state:                                           80
   Internal object pointer:                                           143006328
   Fast connections:                                                  0
DRE : 395996
Conn-ID: 395996 10.98.63.177:51553 -- 10.111.0.14:80  Peer No:  5 Status: Active
Open at 01/14/2013 12:59:43, Still active
Encode:
   Overall: msg:         42, in:  10631 B, out:   1489 B, ratio:  85.99%
       DRE: msg:         42, in:  10467 B, out:   9059 B, ratio:  13.45%
DRE Bypass: msg:         41, in:    164 B
        LZ: msg:         42, in:   9469 B, out:   1489 B, ratio:  84.28%
    Avg latency:      0.070 ms, Avg msg size:    253 B
    0-1K=97%  1K-5K=2%  5K-15K=0%  15K-25K=0%  25K-40K=0%  >40K=0%
Decode:
   Overall: msg:         41, in:   2423 B, out:   8815 B, ratio:  72.51%
       DRE: msg:         41, in:   9033 B, out:   8651 B, ratio:   0.00%
        LZ: msg:         41, in:   2423 B, out:   9443 B, ratio:  74.34%
    Avg latency:      0.042 ms, Avg msg size:    215 B
    0-1K=100%  1K-5K=0%  5K-15K=0%  15K-25K=0%  25K-40K=0%  >40K=0%
Connection details:
      last partial chunk: chunks: 48,  size:   6737 B
      skipped frame header: messages: 41,  size:    164 B
  Nacks: total 0
  R-tx: total 0
  Encode LZ latency:      0.028 ms per msg, avg msg size:    225 B
  Decode LZ latency:      0.014 ms per msg, avg msg size:    230 B
  Cache write detail:
TFO : 395996
  EOT state:
  Socket states
     AO : read-shut: N,  write-shut: N,  close: N, fd: 1492
     WAN: read-shut: N,  write-shut: N,  close: N, fd: 1330
          read-inKQ: Y,  write-inKQ: N,  choke: N, envoy: N
  DRE hints:
  Read
     Total bytes:                10631                      2914
     Total number:                  42                        45
     Average size:                 253                        64
     Flow-ctrl stop:                 0                         0
     Peer-choke:                     0                         0
     Processed ack frames:                                     3
     Maximum size:                                             0
     Current size:                                             0
     Average size:                                             0
     Flow-ctrl stop:                                           0
  Encode/Decode:
     Number of calls:               42                        41
     Latency(ms):                 0.07                      0.04
     Send data/ack frames:          42                         2
     Maximum size:                   0                         0
     Current size:                   0                         0
     Average size:                   0                         0
     Flow-ctrl stop:                 0                         0
  Write
     Total bytes:                 1991                      8815
     Total number:                  45                        41
     Avergage size:                 44                       215
     Latency(ms):                 0.01                      0.01
