CM Reports Not Reflect Correct Connection Limit
tammyc
After a successful WAE-674 memory upgrade from 4GB to 8GB which increases the number of optimized connections to 6000 (without Video), I've noticed that the Central Manager Monitoring/Reporting for Optimization/Connection Statistics/Optimized vs Pass-Through Connections Over Time graph still reflects the 2000 device connection limit (the graphed time is 'last hour').  It does show that the number of optimized connections is above the 2000 limit.  But, I'd like the report to actually reflect the correct device connection limit.  What needs to be done?
Amir Asfandyarov
Hello tammyc,
This behaviour is tracked via CSCts76234  "Connection limit is not getting updated after memory upgrade on WAE" and will be addressed in next releases of WAAS SW.
For now the workaround is to de-register and register device with CM.
HTH,
Regards, Amir
