communication between GSS primary manger and GSS backup manager
shibindong
there is firewall between GSS primary and GSS backup, can some one tell me which port (TCP/UDP?) need to be opened to allow two GSS communicate?
thanks
andrew.burns
Level 7
Level 7
There is a chapter on this topic in the administration guide, located here:
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/gss4400series/v3.0/administration/guide/ACLs.html#wp999192
It lists all the ports that need to be opened inbound and outbound for a GSS when all services are active. Note that depending on which services you run you may not need all these ports to be open.
Andrew.
andrew.burns
Level 7
Level 7
Andrew.
