Configuration help - ACE redirection
jbartoldus
Community Member
Please see the below ACE configuration.  It is currently in place for both load balancing and redirection.  Here are the 4 current scenarios...
1. https://www.URL1.com is the desired URL and will be load balanced.  Certificate is for this URL.
2. http://www.URL1.com will redirect the client to https://www/URL1.com for appropriate load balancing.
3. URL1.com resolves to the same vip ip address as www.URL1.com, so http://URL1.com will redirect the client to https://URL1.com
4. https://URL1.com will be load balanced, but client gets a certificate error since the cert is not associated with this address.
How can I redirect http://URL1.com and https://URL1.com to https://www.URL1.com?  Can I create a L7 policy map in addition to the existing L4 policy map?
Thanks for any help you can give.
rserver host URL1-ws07
  ip address 1.1.1.1
  inservice
rserver host URL1-ws08
  ip address 1.1.2.1
  inservice
rserver host URL1-ws09
  ip address 1.1.3.1
  inservice
rserver host URL1-ws10
  ip address 1.1.4.1
  inservice
rserver host URL1-ws06
  ip address 1.1.5.1
  inservice
!************** Generic redirect rserver used by many policy maps to redirect clear text addresses to secure addresses *************
rserver redirect server-rd
  webhost-redirection https://%h%p 301
  inservice
ssl-proxy service URL1
  key URL10911-key
  cert URL10911-cert
  chaingroup verisign-ev-cg
serverfarm host URL1
  description www.URL1.com
  probe port_80
  rserver URL1-ws07 80
    inservice
  rserver URL1-ws08 80
    inservice
  rserver URL1-ws09 80
    inservice
  rserver URL1-ws10 80
    inservice
  rserver URL1-ws06 80
    inservice
sticky http-cookie acecookie sticky-URL1
  cookie insert browser-expire
  replicate sticky
  serverfarm URL1
!***************** Redirect to https *****************
class-map match-all URL1-vip
  2 match virtual-address 2.2.2.2 tcp eq https
class-map match-all URL1-vip-rd
  2 match virtual-address 2.2.2.2 tcp eq www
policy-map type loadbalance first-match URL1-lb
  class class-default
    sticky-serverfarm sticky-URL1
    action https-rewrite
    insert-http X-Forwarded-For header-value "%is"
policy-map type loadbalance first-match URL1-rd
class class-default
    serverfarm server-rd
policy-map multi-match yellow-policy
  class URL1-vip-rd
    loadbalance vip inservice
    loadbalance policy URL1-rd
    loadbalance vip icmp-reply active
  class URL1-vip
    loadbalance policy URL1-lb
    appl-parameter http advanced-options generic-http-parameter-map
    ssl-proxy server URL1
pablo.nxh
Level 8
Level 8
Hi there,
If all the URLs respond to the same VIP then you need to modify your server-rd as follows:
  webhost-redirection https://www.URL1.com/%p 301
  inservice
That would take care of the HTTP part.
For HTTPS we can't do much as decryption happens before URL matching, you'll get the certificate
error before being sent to the correct domain. The only way you can get HTTPS working is either with:
- Wildcard Certificate: *.URL1.com
- SAN certificate: You can include multiple domains into the same SSL certificate.
__ __
Pablo
I was afraid of that.  Thanks for your help Pablo.
