Content Engine 500 yahoo login problem
baclimon
Community Member
Any other admin's recieving the same problem? The strange thing is if you switch IE setting to "Automatically detect proxy settings" it works. Currently the proxy it statically set.
The following situations are possible causing this:
1. Cannot serve requests pointed to the proxy itself. 2. Using Browser Auto-configuration feature without enable this feature in proxy. 3. Using Browser
Has anyone ran into this problem.
User's are recieving the below error when trying to log into yahoo mail.
Auto-configuration feature without download auto-configuration file onto proxy.
Please contact administrator if you have still question.
Zach Seils
Level 11
Level 11
How is your Content Engine (CE) configured? After you change the configuration setting in IE, can you verify that the request is still be routed through the CE (as opposed to bypassing it)?
~Zach
