Content Engine Module is logging DHCP errors
cscherb
Level 3
Level 3
Content Engine Module in Cisco 3725 is logging the following eror continously:
Sep 29 16:47:50 ContentEngine dhclient: %CE-DHCP-5-191000: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 4
Sep 29 16:47:54 ContentEngine dhclient: %CE-DHCP-5-191000: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 11
Sep 29 16:47:58 ContentEngine smartd: %CE-SMARTD-3-435000: No Errors Logged
Sep 29 16:48:05 ContentEngine dhclient: %CE-DHCP-5-191000: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 1
Sep 29 16:48:06 ContentEngine dhclient: %CE-DHCP-5-191000: No DHCPOFFERS received.
Sep 29 16:48:06 ContentEngine dhclient: %CE-DHCP-5-191000: No working leases in persistent database - sleeping.
Sep 29 16:48:06 ContentEngine %CE-DHCP-5-191000: Script called with reason: FAIL
Sep 29 16:52:58 ContentEngine smartd: %CE-SMARTD-3-435000: No Errors Logged
Disable the external interface (shutdown) didn't fix the problem:
Sep 29 17:02:05 ContentEngine dhclient: %CE-DHCP-5-191000: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 3
Sep 29 17:02:05 ContentEngine dhclient: %CE-DHCP-3-191000: send_packet: Network is down
Sep 29 17:02:08 ContentEngine dhclient: %CE-DHCP-5-191000: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 3
Sep 29 17:02:08 ContentEngine dhclient: %CE-DHCP-3-191000: send_packet: Network is down
Sep 29 17:02:11 ContentEngine dhclient: %CE-DHCP-5-191000: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 5
Sep 29 17:02:11 ContentEngine dhclient: %CE-DHCP-3-191000: send_packet: Network is down
Sep 29 17:02:16 ContentEngine dhclient: %CE-DHCP-5-191000: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 5
Sep 29 17:02:16 ContentEngine dhclient: %CE-DHCP-3-191000: send_packet: Network is down
Sep 29 17:02:21 ContentEngine dhclient: %CE-DHCP-5-191000: No DHCPOFFERS received.
Sep 29 17:02:21 ContentEngine dhclient: %CE-DHCP-5-191000: No working leases in persistent database - sleeping.
Sep 29 17:02:21 ContentEngine %CE-DHCP-5-191000: Script called with reason: FAIL
Sep 29 17:02:58 ContentEngine smartd: %CE-SMARTD-3-435000: No Errors Logged
Any ideas how to fix this problem ?
rodsmith
Community Member
