Content switch management
jmcglashan
Community Member
We are using NQL's to allow only certain addresses to ssh ftp to the css, which all works fine, however, if we ssh or telnet to the css from an ip address that is not allowed we gain a connection but do not get any prompt back, so we cannot actually do anything we are slightly concerned about this being a security risk, is this normal behaviour ? We have restrict telnet on but we seem to get a connection.
mvoight
Level 4
Level 4
This would be normal behavior as the restricted access is at a higher level in the process. If you want to block at a lower level, you would use an ACL.
