SSL Accel not working on 11501
ns
I have a problem with a CSS11501 with the SSL module installed. The SSL module doesn't accept the traffic on port 443 and it goes directly to the server. The server has a certificate installed and that's how I know that it doesn't work. I access the server on port 80 and 443 without any problem. I've seen a similar post on this issue without a solution and the questions were:
Does the browser support the certificates? I'm using IE 6.0 SP1, I honestly don't know if it's supported but I've enabled all RSA ciphers.
Are there any hits on the stats. None, the only counter that changes is the HASH on the Crypto counter.
Any help is appreciated.
Thanks, Niels
The config is the following:
ssl associate rsakey key1 cert1
ssl associate cert cert1 cert1.pem
!************************** CIRCUIT **************************
circuit VLAN1
ip address 10.60.2.2 255.255.255.0
circuit VLAN2
ip address 10.60.0.80 255.255.255.192
!*********************** SSL PROXY LIST ***********************
ssl-proxy-list Servidores_SSL
ssl-server 1
ssl-server 1 rsakey key1
ssl-server 1 rsacert cert1
ssl-server 1 vip address 10.60.2.1
ssl-server 1 cipher rsa-export1024-with-rc4-56-sha 10.60.0.67 80
ssl-server 1 cipher rsa-export1024-with-des-cbc-sha 10.60.0.67 80
ssl-server 1 cipher rsa-export-with-des40-cbc-sha 10.60.0.67 80
ssl-server 1 cipher rsa-export-with-rc4-40-md5 10.60.0.67 80
ssl-server 1 cipher rsa-with-3des-ede-cbc-sha 10.60.0.67 80
ssl-server 1 cipher rsa-with-des-cbc-sha 10.60.0.67 80
ssl-server 1 cipher rsa-with-rc4-128-sha 10.60.0.67 80
ssl-server 1 cipher rsa-with-rc4-128-md5 10.60.0.67 80
active
!************************** SERVICE **************************
service HTTP
ip address 10.60.0.67
keepalive type http
active
service HTTPS
add ssl-proxy-list Servidores_SSL
slot 2
keepalive type none
type ssl-accel
active
!*************************** OWNER ***************************
owner tripartita
content HTTP
protocol tcp
add service HTTP
balance aca
port 80
active
content SSL-Prueba
balance aca
add service HTTPS
application ssl
protocol tcp
port 443
active
mvoight
The current configuration causes port 443 traffic to go to the SSL module and then the SSL module sends it to 10.60.0.67. This is also listed as a service on the CSS. There is nothing in the configuration in your note that would cause the CSS to send traffic to port 443 on the server. Is the 10.60.2.1 configured on any other device, like a firewall translation, for instance?
Are you saying that "show summary" doesn't show any hits on either content rule?
What URL do you enter on the browser?
What URL do you see on the browser after the attempt has concluded?
Michael
