Cookie for HTTP Load Balancing
gaspolgas
Community Member
I'm getting a lot of bots hitting my site.
Log entries are very similar (except for the source IP):
1.247.32.58 - - [11/Dec/2012:22:57:03 -0800] "POST  /?ptrxcz_Ah5qDayLi6TrEbzVtPwSqMtGmJgDa7
HTTP/1.1" 403 3985 "-" "Mozilla/4.0  (compatible; MSIE 6.0; Windows NT 5.1; SV1)
Can someone give me an example of how I can filter these out based the "/?ptrxcz..." part? Most of these requests
have this string in them.
100 match http cookie testcookie1 cookie-value ptrxcz?
Do I need a secondary name? I don't quite understand the syntax.
Thanks!
5 Replies 5
chrhiggi
Level 8
Level 8
class-map type http loadbalance match-all BotMatches
  2 match http cookie secondary ptrxcz.* cookie-value ".*" (look for anything preceeding a ? in a url that starts with ptrxcz. If it has an =, match any value that follows it.)
policy-map type loadbalance first-match Policy_80
  class BotMatches
    drop (Send a reset if we match this class)
  class class-default
    serverfarm Servers
policy-map multi-match Vips
  class Vip_80
    loadbalance vip inservice
    loadbalance policy Policy_80
Thanks, Christopher. That doesn't seem to work though.
Does it matter that this is a POST request?
Does the secondary name argument (ptrxcz.*) accept regex? This bot seems to generate random strings that being with "ptrxcz".
Thanks!
Can I get a capture file and the configuration you applied?
Chris
Here you go:
policy-map type loadbalance first-match abc.ca.prod.http-l7slb
  class abc.ca.http-l7class
    drop
  class class-default
    serverfarm SF_nocms.prod
policy-map multi-match int194-webhosting
  class abc.ca.prod.http
    loadbalance policy abc.ca.prod.http-l7slb
class-map match-all abc.ca.prod.http
  2 match virtual-address 111.111.111.167 tcp eq www
class-map type http loadbalance match-all abc.ca.http-l7class
  10 match http cookie secondary ptrxcz.* cookie-value ".*"
Here's a bigger snippet of what I see in the logs:
187.244.110.209 - - [12/Dec/2012:15:31:35 -0800] "POST /?ptrxcz_uCVmQegPo4Y4Y3YYoCqB0mj5Ptk8ev HTTP/1.1" 403 3985 "-" "Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; SV1)"
87.69.255.148 - - [12/Dec/2012:15:31:35 -0800] "POST /?ptrxcz_MMMMMMMMMMMMMNNNNNNNNNNNNNNNNN HTTP/1.1" 403 3985 "-" "Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; SV1)"
180.246.22.189 - - [12/Dec/2012:15:31:36 -0800] "POST /?ptrxcz_555555566666666666667777777777 HTTP/1.1" 403 3985 "-" "Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; SV1)"
201.137.39.236 - - [12/Dec/2012:15:31:36 -0800] "POST /?ptrxcz_pppqqqqqqqrrrrrrrssssssstttttu HTTP/1.1" 403 3985 "-" "Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; SV1)"
203.127.8.98 - - [12/Dec/2012:15:31:36 -0800] "POST /?ptrxcz_WXXXXXXXYYYYYYYYYYYZZZZZZZZZZZ HTTP/1.1" 403 3985 "-" "Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; SV1)"
Thanks again.
Ok... Apparently, I unknowingly lied.
You can put a wildcard match in the cookie value like this:
ACE4710-ESC1/Admin(config-cmap-http-lb)# match http cookie secondary xyz cookie-value .*
Which will match  /index.html?xyz=
However... if you try this:
ACE4710-ESC1/Admin(config-cmap-http-lb)# match http cookie secondary xyz.* cookie-value .*
We will match /index.html?xyz.*=
The .* is a litteral.  I poked around in the bug database and found CSCsu67264 which was an enhancement request to allow wildcard names for secondary cookies (filed on A3(1.0) code.) It is still in a "New" state, with no updates which means there were not enough customers that required the feature to code it.  We are out of luck....
Chris
