Cookie Insert-Based Persistence
raymondjj
Community Member
I'm slightly confused by the relationship between the various timers with relation to cookies.
For example, I want to use the "cookie insert" feature to provide persistence, but only across sessions. To do this I think I need to modify the COOKIE_INSERT_EXPIRATION_DATE variable to set it to null.
So far so good.
1) do I need to do anything more (like match cookie) to enable this persistence? or does it happen automatically?
2) if I do this what effect does the timer values have on persistence? (i.e. there is a default timeout of 1440 minutes - does this get ignored?)
thanks,
Ray.
setting COOKIE_INSERT_EXPIRATION_DATE to null makes "inserted cookie" session based cookie.
You just need to
1. Define a sticky group with insert cookie
sticky 19 cookie APP1-cookie insert timeout 30
(timeout defined here has no significance, CSM will insert cookie "APP1-cookie" in the server responses.Cookie values will be different for all the reals)
2. And Assign it to a VServer/ policy
vserver APP1-VS
virtual 10.10.10.12 tcp www
serverfarm APP1-SF
sticky 30 group 19
replicate csrp sticky
replicate csrp connection
persistent rebalance
inservice
Syed Iftekhar Ahmed
