Cookie Offset
mark.hansel
Community Member
I want to use a Cookie for session persitence. I can "see" the cookie using a packet sniffer and want to use the unique portion of it. How do I determine the number of bytes that the cookie is offset? I'm using Ethereal Packet Sniffer BTW. If needed I could post the sniffer trace file.
Thanks in advance
Gilles Dufour
the cookie is in the form name=xxxxxxvaluexxxx
the offset is the number of X [characters] after the equal and before the value.
In the example above, the offset would be 6 and the length 5.
Gilles.
