CSM and Bridging mode
tholmes
Hello
I need to configure a CSM into bridging mode (its routed at the moment - and working fine via the VIP)
Some users need admin access to the servers via their real IP addresses
When I tried the following configuration it crashed the users on VLAN128, I couldn't PING VLAN128 IP address
If anyone could give this config a quick 'once over' and see if it looks ok I'd appreciate it, I'm going back in Sunday to try again
Thanks Tony
module ContentSwitchingModule 9
vlan 128 client
ip address 10.129.128.10 255.255.252.0
gateway 10.129.128.1
vlan 110 server
real 10.129.128.101
inservice
real 10.129.128.102
inservice
serverfarm WEB1
nat server
no nat client
real 10.129.128.101
inservice
real 10.129.128.102
inservice
exit
vserver VIP1
virtual 10.129.128.254 any
serverfarm WEB1
advertise active
persistent rebalance
inservice
interface GigabitEthernet6/3
description *** Real Server 1 ***
no ip address
switchport
switchport access vlan 110
interface GigabitEthernet6/4
description *** Real Server 2 ***
no ip address
switchport
interface Vlan128
user vlan
ip address 10.129.128.1 255.255.252.0
If you could not ping the MSFC either, there was a L2 issue somewhere.
I would suggest to configure the MSFC first.
Verify connectivity between MSFC and client.
Then configure the CSM.
Do you know you do not need bridge mode to access the server directly ?
You could catch the traffic using a vserver with ip/mask equal to the subnet of the server and a predictor forward serverfarm.
Gilles.
Gilles Dufour
so can you ping the msfc ip address from the clients ?
If yes, can you ping 10.129.128.10 from the msfc ?
can you ping 10.129.128.10 from the clients ?
The config looks good.
I would check the arp table of msfc and csm.
sho mod csm 9 arp
Gilles.
Thanks for the speedy reply Gilles, I'm not on site now so can't PING test at the moment.
I recall PINGs failed from the clients to the MSFC IP address though. I cleared the arp cache a few times to no avail before having to reload the switch to get them working again (Major car manufacturer - not overly pleased :-) )
I've got a nagging doubt over the fact that the MSFC IP address VLAN(D/G for the real clients) is in the same subnet as the CSM Client and CSM Server IP addresses range.
I think the config is ok too, maybe converting from routed to bridged in a live environment wasn't such a good idea, I'll clear it off and reload before configuring bridging.
Cheers Tony
Gilles.
Hi Gilles,
Thanks for your help, the company dictated using bridge mode so I was stuck with it.
I think you were right, it was a layer 2issue. I reconfigured this morning and it all worked first time!
Cheers for the assistance
Tony
