CSM Cleaning connections?
mruuth
I have webservers on servervlan at a DMZ with databaseconnection to servers on inside. A sniffertrace show that servers can't send packets because some component has cleared the connection. I see old sessions in the FWSM but I don't see connections in CSM because Webservers IP-address is not declared in CSM and DB-server is not LB. Is it possible that CSM is cleaning sessions that are not "configured" every 420 seconds?
Gilles Dufour
420 sec is not a default timer on the CSM.
Is the connection asymetric ? Could the response bypass the CSM ?
Is the server initiated traffic hitting a vserver or not ?
Would be good to have the config and a small drawing showing the CSM and the client/server sowe can understand what is going on.
Is the problem occuring with every connection attempted between these 2 hosts ?
Gilles.
Gilles,
I am now trying to set up a testenvironment. I will come back later with information. Hopefully on this side of New Year.
Mats
