CSM connection stats missing?
scott-goodwin
Level 3
Level 3
I have a policy-map to insert an Ip address into the http header. I am also binding this to a sticky group using src ip address(See policy ICHAIN1-INSERT).
When I initiate a connection within the policy, although the connection is successful, when I try to view the connection stats (show mod csm 3 conns) my client is not listed in the connection table.
When I remove the "sticky-group 10" command then show the connection table, I see my client listed.
Is this normal behaviour?
Also when I issue the show sticky command the real ip's are garbled as shown:-
10 ip 143.52.208.19 D^OI^TD^Z^P!KP 65282
10 ip 10.6.1.14 P2^hD^Z^D^B*^X 79985
Config;
module ContentSwitchingModule 2
ft group 1 vlan 107
priority 20 alt 10
preempt
vlan 105 client
ip address 10.14.105.6 255.255.255.0
gateway 10.14.105.1
natpool CSM-PR1-USERS 10.14.105.10 10.14.105.18 netmask 255.255.255.0
probe ICHAIN-HTTP1 tcp
interval 10
failed 60
port 80
probe ZEN-APPS1-PRB tcp
interval 10
failed 60
port 524
probe ZEN-LDAP1-PRB tcp
interval 10
failed 60
port 636
probe ZEN-SERVER1-PRB tcp
interval 10
failed 60
port 524
map ICHAIN1-X-FOR header
insert protocol http header X-Forwarded-For header-value %is
real BONG
address 143.52.2.120
inservice
real HUORN
address 10.11.33.44
inservice
real ICHAIN101
address 10.14.72.21
inservice
real ICHAIN202
address 10.14.72.70
inservice
real JOSHUA
address 143.52.2.121
inservice
real KARAKA
address 143.52.2.42
inservice
real KARO
address 10.11.33.30
inservice
real PATE
address 10.11.33.32
inservice
serverfarm ICHAIN-BB1
nat server
nat client CSM-PR1-USERS
predictor leastconns
real name ICHAIN1
inservice
real name ICHAIN2
inservice
probe ICHAIN-HTTP1
serverfarm ZEN-APPS1
nat server
real name BONG
inservice
real name JOSHUA
inservice
real name KARO
inservice
real name PATE
inservice
probe ZEN-APPS1-PRB
serverfarm ZEN-LDAP1
nat server
real name HUORN
inservice
real name KARAKA
inservice
probe ZEN-LDAP1-PRB
serverfarm ZEN-SERVER1
nat server
real name HUORN
inservice
real name KARAKA
inservice
sticky 10 netmask 255.255.255.255 timeout 2880
header-map ICHAIN1-X-FOR
sticky-group 10
vserver VIP-ICHAIN1
virtual 10.14.105.20 tcp www
sticky 2880 group 10
replicate csrp sticky
replicate csrp connection
persistent rebalance
slb-policy ICHAIN1-INSERT
inservice
vserver VIP-ICHAIN1-SSL
virtual 10.14.105.20 tcp https
sticky 1440 group 10
inservice
vserver ZEN-APPS1-VIP
virtual 10.14.105.21 tcp 0
inservice
vserver ZEN-LDAP1-VIP
virtual 10.14.105.22 tcp 0
inservice
vserver ZEN-SERVER1-VIP
virtual 10.14.105.23 tcp 0
inservice
Many Thanks
Scott
Gilles Dufour
Scott,
for the garbage output, this is an IOS bug
CSCsa77410 - CSM:C2R2: show mod csm sticky cmd shows garbage real server ip address
How do you show the list of connections ?
Do you specify any parameter or you list all ?
What csm version and ios version do you run currently ?
Gilles.
Hello, I have the same problem running CSM Ver 4.1(7)
Showing connection stats with any of
show module csm 4 conn
show module csm 4 real
do not show any connections nor does it matter if I specify vserver or client or detail as the options
I am using cookie-based sticky and the show mod csm 4 sticky command seems to give correct info so that is not an issue for me
