CSM: difference between FAILED and PROBE_FAILED
ralfvd
Community Member
What are the main differences between FAILED and PROBE_FAILED status on the CSM ?
Are connections still going to a real server when it is in PROBE_FAILED status ?
The probe itself seems to work (it detects the port not being open), but connections are still going to the failing real server.
Thanks in advance,
Ralf
jfoerster
Level 8
Level 8
Hi Ralf,
in my opinion failed means not able to do arp resolution
Probe-Failed means you defined a probe to test if the service is alive and this probe failed (i.e. a connect to tcp port x was not successfull)
In regards to your second issue: Normaly not, only existing connections might try to get this real if you have not defined a failaction. (i.e. if you are having a layer 3 rule everytraffic from the client will try to hit the real even if a probe fail occured except you have definend a failaction like reassign or something like that)
Hope that helps,
Joerg
